주요 콘텐츠로 건너뛰기
TOSHIBA Satellite E45W-C4200X Battery Replacement
필요한 것
  1. TOSHIBA Satellite E45W-C4200X Battery Replacement, Battery: 1 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the ten 1 mm screws that secure the back cover using a Phillips #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X Battery Replacement: 2 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X Battery Replacement: 2 단계, 이미지 2/2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
    • Lift and remove the casing.
  3. TOSHIBA Satellite E45W-C4200X Battery Replacement: 3 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X Battery Replacement: 3 단계, 이미지 2/2
    • Gently lift the flap covering the top side of the battery.
  4. TOSHIBA Satellite E45W-C4200X Battery Replacement: 4 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X Battery Replacement: 4 단계, 이미지 2/2
    • Remove the four 0.5 mm screws that hold the battery in using the Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Battery Replacement: 5 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X Battery Replacement: 5 단계, 이미지 2/2
    • Unplug the battery from the motherboard.
  6. TOSHIBA Satellite E45W-C4200X Battery Replacement: 6 단계, 이미지 1/1
    • Remove the battery from the laptop.
결론
다른 3명이 해당 안내서를 완성하였습니다.
John Tangney
회원 가입일: 09/24/19
385 평판
안내서 2개 작성하였습니다
댓글 한 개
My laptop is only working while plugged in i recently changed the battery and the problem persist. Any idea what else it can be ?
Gabriel Meza - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 11
30일 전: 36
전체 시간: 2,048
