주요 콘텐츠로 건너뛰기
TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement
필요한 것
  1. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement, Cooling Fan: 1 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement, Cooling Fan: 1 단계, 이미지 2/2
    • Using the phillips #1 screwdriver, remove the ten 1 mm screws from the back panel of the device.
  2. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 2 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 2 단계, 이미지 2/2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
  3. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 3 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 3 단계, 이미지 2/2
    • Remove the four .5 mm screws that secure the heat sink using a Phillips #1 screwdriver.
  4. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 4 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 4 단계, 이미지 2/2
    • Remove the two 1 mm screws that secure the cooling fan using a Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 5 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 5 단계, 이미지 2/2
    • Disconnect the fan cord from the harness.
    • Remove the cooling fan and heat sink from the laptop.
  6. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 6 단계, 이미지 1/3 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 6 단계, 이미지 2/3 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: 6 단계, 이미지 3/3
    • Carefully peel off the tape holding the heat sink onto the cooling fan.
    • Peel carefully as the tape goes around all four sides.
    • Remove the cooling fan from the heat sink.
결론
Consider purchasing the entire H000085330 Toshiba Thermal Assembly E45DW-C4210. This includes the fan and heat transfer components assembled. As of January 2022, it is $14.00 on e-bay. This makes replacement much easier.
다른 2명이 해당 안내서를 완성하였습니다.
John Tangney
회원 가입일: 09/24/19
385 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 342
