주요 콘텐츠로 건너뛰기
TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement
필요한 것
  1. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement, DC Power Jack: 1 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement, DC Power Jack: 1 단계, 이미지 2/2
    • Remove the ten 1 mm screws that secure the back cover using a Phillip's #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: 2 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: 2 단계, 이미지 2/2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommended that you start from a corner and run the tool along the edge
  3. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: 3 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: 3 단계, 이미지 2/2
    • Using a Phillips # 1 screwdriver, remove the three screws holding the bracket over the ports on the right side.
    • Remove the bracket.
  4. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: 4 단계, 이미지 1/3 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: 4 단계, 이미지 2/3 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: 4 단계, 이미지 3/3
    • Unplug the power cable harness from the motherboard.
    • Lift the power jack out of its slot in the top right corner.
    • Remove the cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
masato tsuchida
회원 가입일: 09/23/19
348 평판
안내서 2개 작성하였습니다
댓글 한 개
Thanks for this. Great help in sorting out my laptop.
Jack - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 5
30일 전: 12
전체 시간: 586
