주요 콘텐츠로 건너뛰기
TOSHIBA Satellite E45W-C4200X Screen Replacement
필요한 것
  1. TOSHIBA Satellite E45W-C4200X Screen Replacement, Screen: 1 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Using a plastic opening tool, remove the plastic bar underneath the screen.
    • Use caution when removing the plastic bar to prevent cracking.
  2. TOSHIBA Satellite E45W-C4200X Screen Replacement: 2 단계, 이미지 1/1
    • Use the Phillips #1 screwdriver and remove the four screws at the bottom of the screen.
    • Be sure to store the screws in a safe place to prevent losing them.
  3. TOSHIBA Satellite E45W-C4200X Screen Replacement: 3 단계, 이미지 1/3 TOSHIBA Satellite E45W-C4200X Screen Replacement: 3 단계, 이미지 2/3 TOSHIBA Satellite E45W-C4200X Screen Replacement: 3 단계, 이미지 3/3
    • Use the blue plastic opening tool to start separating the plastic cover from the screen.
    • Once started, use the Jimmy to run along the edges to complete the separation.
    • Be sure to go very slow to avoid cracking the glass further and possibly cutting yourself.
    • The camera is still connecting the protective cover to the laptop; we recommend setting it on top of the keyboard.
  4. TOSHIBA Satellite E45W-C4200X Screen Replacement: 4 단계, 이미지 1/1
    • Remove the remaining screws that hold the screen in place using the Phillips #1 screwdriver.
    • Carefully lift out the screen and fold on its face.
    • The screen is still attached, do not pull away from the laptop.
  5. TOSHIBA Satellite E45W-C4200X Screen Replacement: 5 단계, 이미지 1/3 TOSHIBA Satellite E45W-C4200X Screen Replacement: 5 단계, 이미지 2/3 TOSHIBA Satellite E45W-C4200X Screen Replacement: 5 단계, 이미지 3/3
    • Disconnect the screen from the small circuit board.
    • Gently disconnect with even pressure on both sides to prevent damage.
    • The old screen has now been completely removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
masato tsuchida
회원 가입일: 09/23/19
348 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 11
30일 전: 36
전체 시간: 1,803
