주요 콘텐츠로 건너뛰기
TOSHIBA Satellite E45W-C4200X TrackPad Replacement
필요한 것
  1. TOSHIBA Satellite E45W-C4200X TrackPad Replacement, Battery: 1 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the ten 1 mm screws that secure the back cover using a Phillips #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: 2 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: 2 단계, 이미지 2/2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
    • Lift and remove the casing.
  3. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: 3 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: 3 단계, 이미지 2/2
    • Gently lift the flap covering the top side of the battery.
  4. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: 4 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: 4 단계, 이미지 2/2
    • Remove the four 0.5 mm screws that hold the battery in using the Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: 5 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: 5 단계, 이미지 2/2
    • Unplug the battery from the motherboard.
  6. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: 6 단계, 이미지 1/1
    • Remove the battery from the laptop.
  7. TOSHIBA Satellite E45W-C4200X TrackPad Replacement, TrackPad: 7 단계, 이미지 1/1
    • Use the heat gun to heat the top of the keyboard cover to loosen the adhesive.
  8. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: 8 단계, 이미지 1/2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: 8 단계, 이미지 2/2
    • Use the spudger to peel up the keyboard cover.
    • Use caution when removing keyboard cover.
  9. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: 9 단계, 이미지 1/3 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: 9 단계, 이미지 2/3 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: 9 단계, 이미지 3/3
    • Use the heat gun to apply heat to the track pad and use the metal spudger to remove the track pad.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 6
전체 시간: 304
