주요 콘텐츠로 건너뛰기
TRS-80 Color Computer Keyboard Replacement
필요한 것
  1. TRS-80 Color Computer Keyboard Replacement, Outside Casing: 1 단계, 이미지 1/1
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
  2. TRS-80 Color Computer Keyboard Replacement: 2 단계, 이미지 1/2 TRS-80 Color Computer Keyboard Replacement: 2 단계, 이미지 2/2
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
  3. TRS-80 Color Computer Keyboard Replacement, Keyboard: 3 단계, 이미지 1/2 TRS-80 Color Computer Keyboard Replacement, Keyboard: 3 단계, 이미지 2/2
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Christopher Paige
회원 가입일: 01/21/11
549 평판
안내서 3개 작성하였습니다
Cal Poly, Team 11-24, Maness Winter 2011 Cal Poly, Team 11-24, Maness Winter 2011 회원
CPSU-MANESS-W11S11G24
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
This only applies for Color Computers issued after the CoCo 1 F Board (as shown) RS catalog 26-3004 and subsequent models (CoCo 2 & 3). Early editions of the CoCo 1 had not a mylar ribbon cable like this but a heavier ribbon composed of actual wires, the connector they went into was also built for this type of ribbon. The keyboards on each category of connecting ribbon are sadly not interchangeable.
Rogelio Perea - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 8
전체 시간: 3,195
