주요 콘텐츠로 건너뛰기
TRS-80 Color Computer Motherboard Replacement
필요한 것
  1. TRS-80 Color Computer Motherboard Replacement, Outside Casing: 1 단계, 이미지 1/1
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
  2. TRS-80 Color Computer Motherboard Replacement: 2 단계, 이미지 1/2 TRS-80 Color Computer Motherboard Replacement: 2 단계, 이미지 2/2
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
  3. TRS-80 Color Computer Motherboard Replacement, Keyboard: 3 단계, 이미지 1/2 TRS-80 Color Computer Motherboard Replacement, Keyboard: 3 단계, 이미지 2/2
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
  4. TRS-80 Color Computer Motherboard Replacement, Motherboard: 4 단계, 이미지 1/3 TRS-80 Color Computer Motherboard Replacement, Motherboard: 4 단계, 이미지 2/3 TRS-80 Color Computer Motherboard Replacement, Motherboard: 4 단계, 이미지 3/3
    • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
    • When removing the spring door, make sure to keep the door closed.
  5. TRS-80 Color Computer Motherboard Replacement: 5 단계, 이미지 1/3 TRS-80 Color Computer Motherboard Replacement: 5 단계, 이미지 2/3 TRS-80 Color Computer Motherboard Replacement: 5 단계, 이미지 3/3
    • Remove the 5 jumper cables from the motherboard.
    • Once the jumper cables lift the motherboard up gently; it should lift out easily.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Andrew
회원 가입일: 01/23/11
529 평판
안내서 2개 작성하였습니다
Cal Poly, Team 11-24, Maness Winter 2011 Cal Poly, Team 11-24, Maness Winter 2011 회원
CPSU-MANESS-W11S11G24
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 22
전체 시간: 4,020
