소개
Replace an aging power cord on the TRS-80 Color Computer.
도구
부품
지정된 부품이 없습니다.
Flip the computer over.
Remove the two 24.1mm Phillips screws near the front of the case.
Remove the five 33.0 mm Phillips screws towards the back of the case.
Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
Lift the keyboard out of the case.
Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
When removing the spring door, make sure to keep the door closed.
다른 4명이 해당 안내서를 완성하였습니다.
