주요 콘텐츠로 건너뛰기
TVI Loudspeaker Cone Replacement
필요한 것
  1. TVI Loudspeaker   Cone Replacement, Speaker: 1 단계, 이미지 3개 중 1개 TVI Loudspeaker   Cone Replacement, Speaker: 1 단계, 이미지 3개 중 2개 TVI Loudspeaker   Cone Replacement, Speaker: 1 단계, 이미지 3개 중 3개
    • The frame of the speaker needs to be unscrewed carefully and the frame need to be carefully taken off. This is to not damage the frame itself.
  2. TVI Loudspeaker   Cone Replacement: 2 단계, 이미지 3개 중 1개 TVI Loudspeaker   Cone Replacement: 2 단계, 이미지 3개 중 2개 TVI Loudspeaker   Cone Replacement: 2 단계, 이미지 3개 중 3개
    • The damaged speaker needs to be unscrewed from the cabinet. Then once it is unscrewed, left it up carefully but not too high as it is connected to the amp. Carefully disconnected the cables from the speaker and place the speaker on top of a table.
  3. TVI Loudspeaker   Cone Replacement: 3 단계, 이미지 3개 중 1개 TVI Loudspeaker   Cone Replacement: 3 단계, 이미지 3개 중 2개 TVI Loudspeaker   Cone Replacement: 3 단계, 이미지 3개 중 3개
    • The cone, dust cone, gasket, suspension and surround have to be taken off by cutting it and slicing it out with a box cutter or exacto knife.
  4. TVI Loudspeaker   Cone Replacement: 4 단계, 이미지 3개 중 1개 TVI Loudspeaker   Cone Replacement: 4 단계, 이미지 3개 중 2개 TVI Loudspeaker   Cone Replacement: 4 단계, 이미지 3개 중 3개
    • The original coil must have a can placed over it. The suspension must be glued with gorilla glue then the cone. The dust cover needs to be glued in the center of the speaker. The surround then has to be glued around the speakers frame, but carefully as there are screw holes that must be cleared from the surround. Wait for the glue to harden.
  5. TVI Loudspeaker   Cone Replacement: 5 단계, 이미지 3개 중 1개 TVI Loudspeaker   Cone Replacement: 5 단계, 이미지 3개 중 2개 TVI Loudspeaker   Cone Replacement: 5 단계, 이미지 3개 중 3개
    • Once the glue is hardened, connect the cables that originally were connected to the speaker. Then, screw the speaker onto the cabinet and screw the frame on to the cabinet and then you are done.
결론
The significance of our Fixit assignment is to show the ways that fixing this item can be beneficial to our environment and also towards saving our money. Fixing this issue would lead to the contribution to the environment by reducing the amount of plastic that is thrown away. Also, by fixing this, we would save our money and it would be beneficial for everyone. By following these easy steps to repair your TVI speaker, your decision would matter in a significant way towards being eco-friendly and at the same time, being smart in the way you manage your budget.
작성자
2다른 기여자 명과 함께
Group 3
회원 가입일: 10/31/18
121 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 8
전체 시간: 333
