주요 콘텐츠로 건너뛰기
Table Lamp Bulb and Wiring Replacement
필요한 것
  1. Table Lamp Bulb and Wiring Replacement, Bulb and Wiring: 1 단계, 이미지 1개 중 1개
    • Switch off the lamp to ensure no electricity is flowing.
    • Unplug the lamp from the power outlet to prevent the risk of electric shock.
    • Wait a few minutes to allow any remaining electrical charge to dissipate.
  2. Table Lamp Bulb and Wiring Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the screw at the base of the lamp that secures the light fixture to the structure.
    • Use the correct screwdriver/wrench (or if it the screw is loose enough, your hands) to carefully unscrew it while applying steady pressure.
    • Keep the screw in a secure place to avoid losing it during reassembly.
  3. Table Lamp Bulb and Wiring Replacement: 3 단계, 이미지 1개 중 1개
    • Hold the socket (the component that holds the bulb) firmly and check if it is attached with additional screws or clips.
    • Slowly pull the socket out of the fixture while being mindful of the connected wiring.
  4. Table Lamp Bulb and Wiring Replacement: 4 단계, 이미지 3개 중 1개 Table Lamp Bulb and Wiring Replacement: 4 단계, 이미지 3개 중 2개 Table Lamp Bulb and Wiring Replacement: 4 단계, 이미지 3개 중 3개
    • Grip the bulb securely and rotate it counterclockwise to loosen it from the socket.
    • Once removed, inspect the bulb for any visible damage and set it aside if it needs replacement.
  5. Table Lamp Bulb and Wiring Replacement: 5 단계, 이미지 3개 중 1개 Table Lamp Bulb and Wiring Replacement: 5 단계, 이미지 3개 중 2개 Table Lamp Bulb and Wiring Replacement: 5 단계, 이미지 3개 중 3개
    • Take off the white cover from bottom to top.
  6. Table Lamp Bulb and Wiring Replacement: 6 단계, 이미지 2개 중 1개 Table Lamp Bulb and Wiring Replacement: 6 단계, 이미지 2개 중 2개
    • Cut both of the old wires with wire cutters.
  7. Table Lamp Bulb and Wiring Replacement: 7 단계, 이미지 2개 중 1개 Table Lamp Bulb and Wiring Replacement: 7 단계, 이미지 2개 중 2개
    • Take out the new wire and make sure lamp wires correlate to its terminal.
    • Neutral is marked blue, hot is marked red.
  8. Table Lamp Bulb and Wiring Replacement: 8 단계, 이미지 1개 중 1개
    • Thread the wire through the small hole under the lamp.
  9. Table Lamp Bulb and Wiring Replacement: 9 단계, 이미지 2개 중 1개 Table Lamp Bulb and Wiring Replacement: 9 단계, 이미지 2개 중 2개
    • Secure the wires to the screws using a Phillips screwdriver.
    • Tighten the screws so that the wires are secured under the screws.
  10. Table Lamp Bulb and Wiring Replacement: 10 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to screw the wire between its correlating screw.
    • Blue is neutral, red is hot.
  11. Table Lamp Bulb and Wiring Replacement: 11 단계, 이미지 1개 중 1개
    • Plug the lamp in, and the bulb will light up.
결승점
작성자
3다른 기여자 명과 함께
Jeffrey Cong
회원 가입일: 02/19/25
193 평판
안내서 1개를 작성함
UC Davis, Team 3-3, Andersen Winter 2025 UC Davis, Team 3-3, Andersen Winter 2025 회원
UCD-ANDERSEN-W25S3G3
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 27
전체 시간: 324
