주요 콘텐츠로 건너뛰기
TackLife GSW01A Pump Assembly Replacement
필요한 것
  1. TackLife GSW01A Pump Assembly Replacement, Pump: 1 단계, 이미지 2개 중 1개 TackLife GSW01A Pump Assembly Replacement, Pump: 1 단계, 이미지 2개 중 2개
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • For safety Do Not make adjustments to your equipment without first disconnecting the spark plug.
    • Disconnect the spark plug by grabbing it and pulling it outwards.
  2. TackLife GSW01A Pump Assembly Replacement: 2 단계, 이미지 3개 중 1개 TackLife GSW01A Pump Assembly Replacement: 2 단계, 이미지 3개 중 2개 TackLife GSW01A Pump Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Pull the siphon tube apart from connector.
    • Make sure to alleviate the pressure in the pump by squeezing the trigger, acknowledging where the tip is pointed.
    • Try to twist the high-pressure hose off by hand. If too tight, use Vise-Grips or Channellock pliers on the grip to loosen and remove the hose. Careful to maintain a steady grip lest the handle strip.
  3. TackLife GSW01A Pump Assembly Replacement: 3 단계, 이미지 3개 중 1개 TackLife GSW01A Pump Assembly Replacement: 3 단계, 이미지 3개 중 2개 TackLife GSW01A Pump Assembly Replacement: 3 단계, 이미지 3개 중 3개
    • OPTIONAL: Remove handle for tool and hand clearance.
    • To remove the handle, unscrew the orange triangle knobs on both sides. With a firm grip on both sides pull handle apart from pressure washer.
  4. TackLife GSW01A Pump Assembly Replacement: 4 단계, 이미지 3개 중 1개 TackLife GSW01A Pump Assembly Replacement: 4 단계, 이미지 3개 중 2개 TackLife GSW01A Pump Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the 4 mounting bolts. (M8x20)
    • Use an open-ended or box wrench to loosen the bolts. There is not enough clearance for using a socket wrench.
    • Gently tap with a hammer, while safely holding the wrench in place on the bolt with the other hand to loosen the bolts.
    • Be careful not to strip the heads of bolts.
  5. TackLife GSW01A Pump Assembly Replacement: 5 단계, 이미지 3개 중 1개 TackLife GSW01A Pump Assembly Replacement: 5 단계, 이미지 3개 중 2개 TackLife GSW01A Pump Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the existing pump from motor shaft.
    • Retrieve the shaft key from the keyway inside the pump if it is not on the motor shaft keyseat.
  6. TackLife GSW01A Pump Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Clean and lubricate the motor shaft and key.
    • Dirt and grit on shaft can possibly cause damage to the pump over time.
  7. TackLife GSW01A Pump Assembly Replacement: 7 단계, 이미지 3개 중 1개 TackLife GSW01A Pump Assembly Replacement: 7 단계, 이미지 3개 중 2개 TackLife GSW01A Pump Assembly Replacement: 7 단계, 이미지 3개 중 3개
    • Correctly set the shaft key and hold in place while sliding the pump onto the motor shaft.
    • Align the keyway inside the pump with the key and slide the pump onto the motor shaft.
    • If key is not properly set, it could possibly cause damage to the pump or motor shaft.
  8. TackLife GSW01A Pump Assembly Replacement: 8 단계, 이미지 3개 중 1개 TackLife GSW01A Pump Assembly Replacement: 8 단계, 이미지 3개 중 2개 TackLife GSW01A Pump Assembly Replacement: 8 단계, 이미지 3개 중 3개
    • Reinstall the 4 mounting bolts.
    • Rotate the pump so that the hose feeds are properly positioned, and bolt holes are aligned with holes on motor.
  9. TackLife GSW01A Pump Assembly Replacement: 9 단계, 이미지 3개 중 1개 TackLife GSW01A Pump Assembly Replacement: 9 단계, 이미지 3개 중 2개 TackLife GSW01A Pump Assembly Replacement: 9 단계, 이미지 3개 중 3개
    • Reattach the hoses.
    • Reattach handle if removed in earlier steps (OPTIONAL step #3).
  10. TackLife GSW01A Pump Assembly Replacement: 10 단계, 이미지 3개 중 1개 TackLife GSW01A Pump Assembly Replacement: 10 단계, 이미지 3개 중 2개 TackLife GSW01A Pump Assembly Replacement: 10 단계, 이미지 3개 중 3개
    • Screw the orange triangular knobs back on.
    • Reattach the spark plug.
    • Verify all connections are snug tight before operating the pressure washer.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Mallory A Gullett
회원 가입일: 06/11/20
249 평판
안내서 1개를 작성함
2가이드 댓글
I'm getting milky oil I want to change pump on my tacklife pressure washer 3200 psi what is a good pump?I cant find OEM pump from the number on pump?What size shaft?
Jason Blood - 답글
My pump leaks. Do you know of a gasket kit? What type of replacement oil is used thank you
G Barnes - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 21
전체 시간: 2,012
