주요 콘텐츠로 건너뛰기
Tagital T10 Speaker Replacement
필요한 것
  1. Tagital T10 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Always make sure your device is completely powered off before performing repairs.
    • Remove the two 4mm screws at the top of the device.
  2. Tagital T10 Speaker Replacement: 2 단계, 이미지 1/2 Tagital T10 Speaker Replacement: 2 단계, 이미지 2/2
    • Carefully remove the back cover by using a plastic opening tool, moving all the way around the perimeter of the tablet.
    • Set the back cover aside.
    • The speakers are attached to the inside back cover, and are connected by wires to the motherboard of the tablet. Carefully set the back cover aside so that you do not rip the wires free.
  3. Tagital T10 Speaker Replacement: 3 단계, 이미지 1/3 Tagital T10 Speaker Replacement: 3 단계, 이미지 2/3 Tagital T10 Speaker Replacement: 3 단계, 이미지 3/3
    • Locate where the speaker's wires connect to the motherboard.
    • Heat the solder to soften it and disconnect the wires using the soldering tool.
  4. Tagital T10 Speaker Replacement: 4 단계, 이미지 1/2 Tagital T10 Speaker Replacement: 4 단계, 이미지 2/2
    • Remove the old speakers from the back cover with the plastic prying tool.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cody D'Amato
회원 가입일: 09/26/16
303 평판
안내서 2개 작성하였습니다
USF Tampa, Team 14-5, Eyestone Fall 2016 USF Tampa, Team 14-5, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S14G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 184
