주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Use this guide to replace the battery in the Tagital T9X.
부품
지정된 부품이 없습니다.
  1. With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Using a plastic spudger, carefully pry the battery from its position. Ensure that you  do not puncture or bend the battery in this process.
    • Using a plastic spudger, carefully pry the battery from its position. Ensure that you do not puncture or bend the battery in this process.
    • The only wires for removal are the red and black wires that are soldered into the battery and motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Adam Bamforth
회원 가입일: 2016년 02월 01일
517 평판
안내서 4개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 274
