주요 콘텐츠로 건너뛰기
Tagital T9X Speaker Replacement
필요한 것
  1. Tagital T9X Speaker Replacement, Back Cover: 1 단계, 이미지 1/1
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Speaker Replacement: 2 단계, 이미지 1/1
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Tagital T9X Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Detach speaker wires from motherboard.
    • The wires are fragile and may break off while handling them.
  4. Tagital T9X Speaker Replacement: 4 단계, 이미지 1/1
    • Use the plastic spudger to remove speaker from the back panel.
결론
Adam Bamforth
회원 가입일: 02/01/16
517 평판
안내서 4개 작성하였습니다
댓글 한 개
Hi. I need a replacement speaker for my tagital t9x. What part number should I look up?
Jerry - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 113
