주요 콘텐츠로 건너뛰기
Tagital T9X Volume, power, or return button Replacement
필요한 것
  1. Tagital T9X Volume, power, or return button Replacement, Back Cover: 1 단계, 이미지 1/1
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Volume, power, or return button Replacement: 2 단계, 이미지 1/1
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Tagital T9X Volume, power, or return button Replacement, Volume, power, or return button: 3 단계, 이미지 1/1
    • Remove the broken volume button from the plastic case. Replace it with the new volume button, with the + being closer to the camera opening.
    • There are two other small buttons that look very similar to one another; if they fall off as well, put them back in their rightful place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Adam Bamforth
회원 가입일: 02/01/16
517 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 250
