소개
This guide will teach you how to take in the waistband of a skirt that is too large. The instructions work best for skirts that are loose, like rectangle skirts or pleated skirts, and that have a separate waistband and a lining. You will need basic sewing skills, including the ability to sew using a sewing machine.
The guide uses these terms:
- seam: a line of stitching that joins two or more pieces of cloth
- seam ripper: a tool used to remove stitches
- seam allowance: the distance between the stitch line and the edge of the cloth
- right side: the “front” of the fabric; the printed side
- wrong side: the “back” of the fabric
필요한 것
Try on the skirt to see how big it is.
Gather the excess fabric at one of the side seams.
Press the seam allowance on the new side seam flat and fold the top and bottom down.
Align the top edges of the inner and outer waistbands with the wrong sides facing together. Use straight pins to hold the fabric in place.
Stitch across the top of the waistband, right next to the edge. Make sure to begin where the original stitching ends to avoid leaving holes in the waistband.
With right sides together, match the side seam of the lining to the side seam of the waistband and secure with straight pins.
Stitch the lining to the inner waistband.
Turn the skirt right side out.
Top stitch along the bottom edge of the outer waistband to secure it to the inner waistband.
Your skirt is now finished! Wear it with pride.
다른 한 분이 해당 안내서를 완성하였습니다.
