주요 콘텐츠로 건너뛰기
Tapwave T2907US Zodiac 2 Directional Pad Replacement
필요한 것
  1. Tapwave T2907US Zodiac 2 Directional Pad Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Remove the four Torx T5 screws from the back panel.
  2. Tapwave T2907US Zodiac 2 Directional Pad Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge a spudger in between the front and back panel.
    • Apply leverage downwards to the spudger in order to remove the back panel.
  3. Tapwave T2907US Zodiac 2 Directional Pad Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Slide the battery out from under the brown wire-tape.
    • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
  4. Tapwave T2907US Zodiac 2 Directional Pad Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
  5. Tapwave T2907US Zodiac 2 Directional Pad Replacement, Directional Pad: 5 단계, 이미지 1개 중 1개
    • Unscrew the 2 Philips #00 screws on each end of the motherboard.
  6. Tapwave T2907US Zodiac 2 Directional Pad Replacement: 6 단계, 이미지 1개 중 1개
    • Pull off the black memory card slot piece.
  7. Tapwave T2907US Zodiac 2 Directional Pad Replacement: 7 단계, 이미지 1개 중 1개
    • Unscrew the 2 Philips #00 screws on each side of the charging port.
  8. Tapwave T2907US Zodiac 2 Directional Pad Replacement: 8 단계, 이미지 2개 중 1개 Tapwave T2907US Zodiac 2 Directional Pad Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
  9. Tapwave T2907US Zodiac 2 Directional Pad Replacement: 9 단계, 이미지 1개 중 1개
    • Grasp the upper left edge of the motherboard and slide diagonally up and left away from the auxiliary port entrance.
    • Glue connecting the port to the casing may make it difficult to remove. Gently apply force as needed.
  10. Tapwave T2907US Zodiac 2 Directional Pad Replacement: 10 단계, 이미지 1개 중 1개
    • Unscrew the 2 silver Philips #00 screws from both sides of the directional pad component on the front casing.
  11. Tapwave T2907US Zodiac 2 Directional Pad Replacement: 11 단계, 이미지 2개 중 1개 Tapwave T2907US Zodiac 2 Directional Pad Replacement: 11 단계, 이미지 2개 중 2개
    • Take out the 2 pieces of the directional pad with tweezers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Daniel Wiseman
회원 가입일: 01/20/12
133 평판
안내서 6개를 작성함
Cal Poly, Team 10-33, Amido Winter 2012 Cal Poly, Team 10-33, Amido Winter 2012 회원
CPSU-AMIDO-W12S10G33
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 7
전체 시간: 760
