이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Wedge a spudger in between the front and back panel.
Apply leverage downwards to the spudger in order to remove the back panel.
Slide the battery out from under the brown wire-tape.
Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
이 단계에 사용된 도구:Tweezers$4.99-
Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
Grasp the upper left edge of the motherboard and slide diagonally up and left away from the auxiliary port entrance.
Unscrew the 2 silver Philips #00 screws from both sides of the directional pad component on the front casing.
다른 한 분이 해당 안내서를 완성하였습니다.
