주요 콘텐츠로 건너뛰기
Tara Traveling Valve Replacement
필요한 것
  1. Tara Traveling Valve Replacement, Handle: 1 단계, 이미지 1/1
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Use a Tara tool to loosen the jam nuts on either side of the pump.
    • The bolts do not need to be loosened or removed, only the nuts need to be loosened.
  2. Tara Traveling Valve Replacement: 2 단계, 이미지 1/3 Tara Traveling Valve Replacement: 2 단계, 이미지 2/3 Tara Traveling Valve Replacement: 2 단계, 이미지 3/3
    • Unscrew the lock bolts about half an inch.
    • The bolts do not need to be removed from the base.
  3. Tara Traveling Valve Replacement: 3 단계, 이미지 1/2 Tara Traveling Valve Replacement: 3 단계, 이미지 2/2
    • Pull the plastic bushing and handle straight up out of the pump.
    • If the bushing doesn't come up, loosen the lock bolts further.
  4. Tara Traveling Valve Replacement: 4 단계, 이미지 1/2 Tara Traveling Valve Replacement: 4 단계, 이미지 2/2
    • Lift up the handle and riser main until the joint between the two is at a comfortable height to work on.
  5. Tara Traveling Valve Replacement: 5 단계, 이미지 1/3 Tara Traveling Valve Replacement: 5 단계, 이미지 2/3 Tara Traveling Valve Replacement: 5 단계, 이미지 3/3
    • Loosen the jam nut beneath the pump handle using the Tara tool.
  6. Tara Traveling Valve Replacement: 6 단계, 이미지 1/2 Tara Traveling Valve Replacement: 6 단계, 이미지 2/2
    • Unscrew the pump handle from the top of the riser main.
    • Make sure someone is tightly holding the lower portion of the riser main to prevent losing it down the well.
  7. Tara Traveling Valve Replacement: 7 단계, 이미지 1/2 Tara Traveling Valve Replacement: 7 단계, 이미지 2/2
    • Lift and remove the handle from the pump. Store the handle in a sanitary place to prevent contamination.
  8. Tara Traveling Valve Replacement, Pump Rod: 8 단계, 이미지 1/3 Tara Traveling Valve Replacement, Pump Rod: 8 단계, 이미지 2/3 Tara Traveling Valve Replacement, Pump Rod: 8 단계, 이미지 3/3
    • Screw the T-handle onto the top of the riser main.
  9. Tara Traveling Valve Replacement: 9 단계, 이미지 1/2 Tara Traveling Valve Replacement: 9 단계, 이미지 2/2
    • Tighten the jam nut up against the base of the T-handle.
  10. Tara Traveling Valve Replacement: 10 단계, 이미지 1/3 Tara Traveling Valve Replacement: 10 단계, 이미지 2/3 Tara Traveling Valve Replacement: 10 단계, 이미지 3/3
    • Use the T-handle to push the riser main back down into the well.
  11. Tara Traveling Valve Replacement: 11 단계, 이미지 1/3 Tara Traveling Valve Replacement: 11 단계, 이미지 2/3 Tara Traveling Valve Replacement: 11 단계, 이미지 3/3
    • Once the riser main hits the bottom, turn the T-handle while pushing down.
    • This will hook the foot valve onto the traveling valve, allowing you to pull the two out of the well together.
    • You should feel some resistance if the foot valve is successfully attached.
  12. Tara Traveling Valve Replacement: 12 단계, 이미지 1/2 Tara Traveling Valve Replacement: 12 단계, 이미지 2/2
    • Use the T-handle to pull the riser main straight up out of the well.
    • Take care to pull up slowly to ensure the foot valve does not get released from the hook at the end of the riser main.
  13. Tara Traveling Valve Replacement: 13 단계, 이미지 1/2 Tara Traveling Valve Replacement: 13 단계, 이미지 2/2
    • Continue pulling the riser main up from the well.
    • Pull the riser main until the base of the T-handle is at a comfortable height to work on.
  14. Tara Traveling Valve Replacement: 14 단계, 이미지 1/3 Tara Traveling Valve Replacement: 14 단계, 이미지 2/3 Tara Traveling Valve Replacement: 14 단계, 이미지 3/3
    • Loosen the jam nut from the base of the T-handle.
    • Unscrew the T-handle from the top of the riser main.
    • Remove the T-handle, making sure to hold the remaining end of the riser main to prevent dropping it down the well.
  15. Tara Traveling Valve Replacement: 15 단계, 이미지 1/3 Tara Traveling Valve Replacement: 15 단계, 이미지 2/3 Tara Traveling Valve Replacement: 15 단계, 이미지 3/3
    • Continue to pull the riser main out of the well.
  16. Tara Traveling Valve Replacement: 16 단계, 이미지 1/3 Tara Traveling Valve Replacement: 16 단계, 이미지 2/3 Tara Traveling Valve Replacement: 16 단계, 이미지 3/3
    • Keep pulling until the first joint is exposed.
    • Lift the joint up to a comfortable working height.
  17. Tara Traveling Valve Replacement: 17 단계, 이미지 1/3 Tara Traveling Valve Replacement: 17 단계, 이미지 2/3 Tara Traveling Valve Replacement: 17 단계, 이미지 3/3
    • Use two wrenches to loosen the top section of riser main from the lower section.
    • Unscrew the top section of the riser main.
    • Make sure someone is holding the remaining section of the riser main.
  18. Tara Traveling Valve Replacement: 18 단계, 이미지 1/3 Tara Traveling Valve Replacement: 18 단계, 이미지 2/3 Tara Traveling Valve Replacement: 18 단계, 이미지 3/3
    • Remove the top section of the riser main.
  19. Tara Traveling Valve Replacement: 19 단계, 이미지 1/1
    • Lay the first section of riser main in a sanitary place to prevent contamination.
    • Repeat the previous procedure to remove the remaining sections of the riser main from the well.
    • Lay each new piece in the order it was removed to aid in reassembly.
  20. Tara Traveling Valve Replacement: 20 단계, 이미지 1/3 Tara Traveling Valve Replacement: 20 단계, 이미지 2/3 Tara Traveling Valve Replacement: 20 단계, 이미지 3/3
    • The last section of riser main will have the traveling valve screwed on to the end, and the foot valve hooked onto the traveling valve.
    • Be careful not to allow the foot valve to release from the hook by pulling slowly on the riser main.
  21. Tara Traveling Valve Replacement: 21 단계, 이미지 1/3 Tara Traveling Valve Replacement: 21 단계, 이미지 2/3 Tara Traveling Valve Replacement: 21 단계, 이미지 3/3
    • Lift and twist the foot valve to unhook it from the traveling valve.
  22. Tara Traveling Valve Replacement: 22 단계, 이미지 1/1
    • Once the riser main and valves have been removed from the well, place a rag over the top to prevent accidentally dropping anything down the well.
  23. Tara Traveling Valve Replacement, Traveling Valve: 23 단계, 이미지 1/2 Tara Traveling Valve Replacement, Traveling Valve: 23 단계, 이미지 2/2
    • While holding onto the pump rod, use a Tara tool to loosen the jam nut from the hook.
  24. Tara Traveling Valve Replacement: 24 단계, 이미지 1/3 Tara Traveling Valve Replacement: 24 단계, 이미지 2/3 Tara Traveling Valve Replacement: 24 단계, 이미지 3/3
    • Unscrew and remove the hook from the base of the pump rod.
  25. Tara Traveling Valve Replacement: 25 단계, 이미지 1/3 Tara Traveling Valve Replacement: 25 단계, 이미지 2/3 Tara Traveling Valve Replacement: 25 단계, 이미지 3/3
    • Remove the jam nut from the base of the pump rod.
    • Remove the washer.
    • Remove the traveling valve components.
  26. Tara Traveling Valve Replacement: 26 단계, 이미지 1/3 Tara Traveling Valve Replacement: 26 단계, 이미지 2/3 Tara Traveling Valve Replacement: 26 단계, 이미지 3/3
    • Check all components for signs of wear or damage.
  27. Tara Traveling Valve Replacement: 27 단계, 이미지 1/3 Tara Traveling Valve Replacement: 27 단계, 이미지 2/3 Tara Traveling Valve Replacement: 27 단계, 이미지 3/3
    • When reassembling the pump, drop the foot valve down the well in the proper orientation, and follow the directions in reverse.
결론
Sam Goldheart
회원 가입일: 10/18/12
465,238 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 16,560개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 181
