주요 콘텐츠로 건너뛰기
Tatung TAC-6G Heating Element Replacement
필요한 것
  1. Tatung TAC-6G Heating Element Replacement, Heating Element: 1 단계, 이미지 1/1
    • Lift the lid and bowl from top of the device
    • Be sure device is not plugged in before beginning replacement of heating element
  2. Tatung TAC-6G Heating Element Replacement: 2 단계, 이미지 1/1
    • Turn the bowl upside down so that the three legs point upwards
  3. Tatung TAC-6G Heating Element Replacement: 3 단계, 이미지 1/2 Tatung TAC-6G Heating Element Replacement: 3 단계, 이미지 2/2
    • Remove the one 7 mm Phillips screw from the side of the brass panel.
  4. Tatung TAC-6G Heating Element Replacement: 4 단계, 이미지 1/2 Tatung TAC-6G Heating Element Replacement: 4 단계, 이미지 2/2
    • Remove the 6mm Phillips screw that holds the stainless plate.
  5. Tatung TAC-6G Heating Element Replacement: 5 단계, 이미지 1/3 Tatung TAC-6G Heating Element Replacement: 5 단계, 이미지 2/3 Tatung TAC-6G Heating Element Replacement: 5 단계, 이미지 3/3
    • Remove all four of the 15mm Phillips screws from all four of the brackets that hold the heating element in place
  6. Tatung TAC-6G Heating Element Replacement: 6 단계, 이미지 1/1
    • Using your hands, remove the heating plate that is on top of heating element.
  7. Tatung TAC-6G Heating Element Replacement: 7 단계, 이미지 1/1
    • Remove the 7mm Phillips screw that holds the white wire connected to the heating element.
  8. Tatung TAC-6G Heating Element Replacement: 8 단계, 이미지 1/1
    • Remove the 7mm Phillips screw that holds the white & maroon wires connected to the heating element.
  9. Tatung TAC-6G Heating Element Replacement: 9 단계, 이미지 1/1
    • Using, your hands, take out the heating element and replace it with a new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
John David Mitchell
회원 가입일: 01/31/16
128 평판
안내서 1개 작성함
University of Alabama, Team 1-6, Sydow campbell Spring 2016 University of Alabama, Team 1-6, Sydow campbell Spring 2016 회원
UA-SYDOW CAMPBELL-S16S1G6
4 회원들
안내서 3개 작성하였습니다
댓글 6개
where can I buy this heating element? Thanks.
dchang168 - 답글
Tze Moh Yeo - 답글
where to buy parts is the problem!!
William Co - 답글
not sell tools here but parts, it’s easy to repair but parts is the problem
William Co - 답글
heat elements can be purchased in Taiwan. if you can read Chinese.
chengshiuntsai - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 25
전체 시간: 4,058
