주요 콘텐츠로 건너뛰기
Taurus G2C Field Strip Disassembly
필요한 것
  1. Taurus G2C Field Strip Disassembly, The basics: 1 단계, 이미지 1/2 Taurus G2C Field Strip Disassembly, The basics: 1 단계, 이미지 2/2
    • WARNING: As a rule of thumb, whenever handling any firearm, treat the weapon as if it is loaded and be mindful of the muzzle of the firearm at all times! "I didn't know it was loaded" isn't an excuse and can't undo mistakes!
    • Before proceeding with this repair, be sure to clear the firearm of ammunition. Check, double check, and triple check to make sure there isn't a bullet in the chamber!
    • The Taurus G2C has a handy Loaded Chamber Indicator to show if there's a bullet in the chamber. Even if it's not showing loaded doesn't mean you should not check!
  2. Taurus G2C Field Strip Disassembly, Field Strip: 2 단계, 이미지 1/2 Taurus G2C Field Strip Disassembly, Field Strip: 2 단계, 이미지 2/2
    • For safety reasons, the serial number has been redacted.
    • After making sure the weapon is clear -no bullet in the chamber- , release the striker by pulling the trigger. This releases the tension on the striker and allows the slide to come forward.
    • Pull the slide back just a hair to release the tension on the disassembly latches. Pull downward on the disassembly latches on both sides while holding rearward pressure on the slide, then release the pressure on the slide.
  3. Taurus G2C Field Strip Disassembly, Separating the slide and the grip: 3 단계, 이미지 1/3 Taurus G2C Field Strip Disassembly, Separating the slide and the grip: 3 단계, 이미지 2/3 Taurus G2C Field Strip Disassembly, Separating the slide and the grip: 3 단계, 이미지 3/3
    • Continue moving the slide forwards until the rear of the slide passes the guides the notches above the disassembly latches(pointed out in the last picture).
  4. Taurus G2C Field Strip Disassembly, Removing the recoil spring assembly: 4 단계, 이미지 1/3 Taurus G2C Field Strip Disassembly, Removing the recoil spring assembly: 4 단계, 이미지 2/3 Taurus G2C Field Strip Disassembly, Removing the recoil spring assembly: 4 단계, 이미지 3/3
    • The recoil spring assembly is on the bottom of the barrel. It is held in place by the spring's own tension against a notch in the barrel (2nd picture) and its slot in the end of the slide.
    • While holding the slide with the muzzle pointing away from you, put your thumb or index finger on the rear-facing portion of the recoil spring assembly. Push the assembly forward to free it from the tension against the barrel, then release the tension and pull it out of its slot in the slide.
  5. Taurus G2C Field Strip Disassembly, Removing the barrel: 5 단계, 이미지 1/3 Taurus G2C Field Strip Disassembly, Removing the barrel: 5 단계, 이미지 2/3 Taurus G2C Field Strip Disassembly, Removing the barrel: 5 단계, 이미지 3/3
    • With the recoil spring assembly no longer holding the barrel in, the barrel can now be removed.
    • Move the barrel slightly towards the bottom of the slide
    • Push the barrel forward a little bit to allow enough space to clear the ejector (not pictured)
  6. Taurus G2C Field Strip Disassembly: 6 단계, 이미지 1/2 Taurus G2C Field Strip Disassembly: 6 단계, 이미지 2/2
    • Lift the barrel out of the slide.
  7. Taurus G2C Field Strip Disassembly, Finished!: 7 단계, 이미지 1/1
    • Always treat any gun as if it were loaded at all times. Also always be mindful of the direction your muzzle is pointed.
    • You're finished! You have now successfully field stripped a Taurus G2C.
결론
To reassemble your weapon, follow these instructions in reverse order.
다른 16명이 해당 안내서를 완성하였습니다.
Josh Boyd
회원 가입일: 10/25/16
841 평판
안내서 1개 작성함
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,521개 작성하였습니다
댓글 5개
Hello Josh. This is Matthew. Thanks for the field stripping instructions. Just wanted to let you know people are using your instructions. Safe shooting and have a good day
Matthew Mackey - 답글
Hey Matthew! Glad to hear people are able to use my guide! Thanks for reaching out!!
Josh Boyd -
Just wanted you to know I just used your information on taking apart my pistol. Great info.
mkoc1018 - 답글
Awesome, glad to hear it helped! Safe shooting and pass the knowledge along!
Josh Boyd -
Thanks for the great tutorial. Very clear and concise.
Jonathon Covey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 18
7일 전: 136
30일 전: 562
전체 시간: 51,339
