소개
The Taylor 342D-27 is a machine that is often used by businesses to make slush-type drinks. A damaged valve will not allow the machine to have a proper seal and the contents will leak. This repair guide can help you replace the o-ring and get the machine back in top shape. The guide can be used when either of the two o-rings located around the valve become loose, damaged, or broken.
필요한 것
Make sure the switch for the machine is straight down in the off position and that all contents have been emptied.
다른 한 분이 해당 안내서를 완성하였습니다.
