소개
The turntable is operated by a motor that spins a belt and the table. The belt may stretch or become misaligned over time, and may need replacement or adjustment. Note that it is first important to complete the Disassembly Guide.
  1. Separate the turntable from the top of the record player by lifting straight up. Separate the turntable from the top of the record player by lifting straight up.
    • Separate the turntable from the top of the record player by lifting straight up.
  2. Check the belt to see if it is off the motor or turntable. If the belt is damaged (tearing or lack of smoothness) replace the belt with a new one. If it is off track, realign accordingly.
    • Check the belt to see if it is off the motor or turntable. If the belt is damaged (tearing or lack of smoothness) replace the belt with a new one. If it is off track, realign accordingly.
    • Do not stretch the belt too far as it may break.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Once the belt is ready to go, re-wrap the belt around the turntable wheel and, keeping it around the wheel, wrap it around the motor (indicated by the red circle). It may be helpful to lay the record player on its side to keep the belt wrapped around both the motor and the turntable wheel. It may be helpful to lay the record player on its side to keep the belt wrapped around both the motor and the turntable wheel.
    • Once the belt is ready to go, re-wrap the belt around the turntable wheel and, keeping it around the wheel, wrap it around the motor (indicated by the red circle).
    • It may be helpful to lay the record player on its side to keep the belt wrapped around both the motor and the turntable wheel.
  5. Once the belt has been re-applied and the turntable re-attached, stand the record player back up.
    • Once the belt has been re-applied and the turntable re-attached, stand the record player back up.
결론
To reassemble your device, follow these instructions in reverse order and complete the disassembly guide in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Charles Lockner
회원 가입일: 2012년 09월 17일
103 평판
안내서 2개 작성하였습니다
Cal Poly, Team 2-61, Propen Fall 2012 Cal Poly, Team 2-61, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G61
4 회원들
안내서 5개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 2,328
