주요 콘텐츠로 건너뛰기
Teac DC-D2831 Drive Belt replacement
필요한 것
  1. Teac DC-D2831 Drive Belt replacement, Drive Belt: 1 단계, 이미지 1/2 Teac DC-D2831 Drive Belt replacement, Drive Belt: 1 단계, 이미지 2/2
    • Separate the turntable from the top of the record player by lifting straight up.
  2. Teac DC-D2831 Drive Belt replacement: 2 단계, 이미지 1/1
    • Check the belt to see if it is off the motor or turntable. If the belt is damaged (tearing or lack of smoothness) replace the belt with a new one. If it is off track, realign accordingly.
    • Do not stretch the belt too far as it may break.
  3. Teac DC-D2831 Drive Belt replacement: 3 단계, 이미지 1/3 Teac DC-D2831 Drive Belt replacement: 3 단계, 이미지 2/3 Teac DC-D2831 Drive Belt replacement: 3 단계, 이미지 3/3
    • Once the belt is ready to go, re-wrap the belt around the turntable wheel and, keeping it around the wheel, wrap it around the motor (indicated by the red circle).
    • It may be helpful to lay the record player on its side to keep the belt wrapped around both the motor and the turntable wheel.
  4. Teac DC-D2831 Drive Belt replacement: 4 단계, 이미지 1/1
    • Once the belt has been re-applied and the turntable re-attached, stand the record player back up.
결론
To reassemble your device, follow these instructions in reverse order and complete the disassembly guide in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Charles Lockner
회원 가입일: 09/17/12
115 평판
안내서 2개 작성하였습니다
Cal Poly, Team 2-61, Propen Fall 2012 Cal Poly, Team 2-61, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G61
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 3,592
