주요 콘텐츠로 건너뛰기
Tech21 NYC MIDI Mouse Tactile Switch Replacement
필요한 것
  1. Tech21 NYC MIDI Mouse Tactile Switch Replacement, Open the enclosure: 1 단계, 이미지 1개 중 1개
    • Open the back of the case by undoing the 4 screws with a regular philips screwdriver.
  2. Tech21 NYC MIDI Mouse Tactile Switch Replacement, Detaching the circuit board: 2 단계, 이미지 2개 중 1개 Tech21 NYC MIDI Mouse Tactile Switch Replacement, Detaching the circuit board: 2 단계, 이미지 2개 중 2개
    • The PCB is attached to the main enclosure by three solder points. These are fairly big and easy to desolder with some wick.
    • This step might be optional. If your desoldering is good enough to leave the pins completely free, you might be able to desolder the switch from here and remove the part at the other side of the board with your hand.
  3. Tech21 NYC MIDI Mouse Tactile Switch Replacement, Desolder the tactile switch: 3 단계, 이미지 2개 중 1개 Tech21 NYC MIDI Mouse Tactile Switch Replacement, Desolder the tactile switch: 3 단계, 이미지 2개 중 2개
    • Small joints, so a bit trickier to desolder.
  4. Tech21 NYC MIDI Mouse Tactile Switch Replacement, Replace the switch: 4 단계, 이미지 2개 중 1개 Tech21 NYC MIDI Mouse Tactile Switch Replacement, Replace the switch: 4 단계, 이미지 2개 중 2개
    • I wrote the guys at Tech21 to ask for the exact part number and they were kind enough to send me two of them. Thanks!
    • Soldering the component is very straight forward.
    • Once the replacement is in place, this is a good moment to connect a DC adapter of 9V battery and check that the new switch works correctly.
  5. Tech21 NYC MIDI Mouse Tactile Switch Replacement, Reattach the board to the case: 5 단계, 이미지 1개 중 1개
    • Fit the board to the mount points and apply generous solder. Make sure to check that the display fits and it's correctly aligned with the case before soldering.
  6. Tech21 NYC MIDI Mouse Tactile Switch Replacement: 6 단계, 이미지 1개 중 1개
    • The obvious last step is to screw again the for screws holding the back of the case.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
palako
회원 가입일: 02/01/15
992 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 13
전체 시간: 642
