주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Technics SL-1900 Turntable Disassembly
필요한 것
  1. Technics SL-1900 Turntable Disassembly, Remove Cover, Platter and Cartridge: 1 단계, 이미지 1개 중 1개
    • Remove the transparent cover from the turntable. It lifts straight up.
    • Remove the phono cartridge assembly from the tone arm. Unscrew the retaining collar to release the assembly and then pull the assembly off.
    • Remove the rubber platter cover from the turntable.
    • Remove the metal platter from the turntable. Insert a finger into each of the large holes, and pull straight up.
  2. Technics SL-1900 Turntable Disassembly, Remove The Top Case: 2 단계, 이미지 3개 중 1개 Technics SL-1900 Turntable Disassembly, Remove The Top Case: 2 단계, 이미지 3개 중 2개 Technics SL-1900 Turntable Disassembly, Remove The Top Case: 2 단계, 이미지 3개 중 3개
    • Remove 8 Phillips screws from the bottom of the turntable. This releases the plastic top of the turntable. You have to move the tone arm toward the center of the unit in order to remove the plastic case top. Set the case top aside.
    • When pulling up on the plastic top, take special care around the three platter speed control knobs, which are mostly hidden under a plastic cover in the lower right corner of the turntable. When you remove the case top, the three knobs will be rattling around underneath the plastic cover.
  3. Technics SL-1900 Turntable Disassembly, Remove Tone Arm Assembly: 3 단계, 이미지 3개 중 1개 Technics SL-1900 Turntable Disassembly, Remove Tone Arm Assembly: 3 단계, 이미지 3개 중 2개 Technics SL-1900 Turntable Disassembly, Remove Tone Arm Assembly: 3 단계, 이미지 3개 중 3개
    • The tone arm assembly is held in place by three screws on top, and three long screws on the bottom.
    • Beginning on the bottom, remove the three long screws that secure the assembly from the bottom.
    • Remove the two marked screws at the base of the tone arm assembly.
    • Remove the rubber plug covering the third screw. Remove the hidden screw.
  4. Technics SL-1900 Turntable Disassembly, Detach Wires from Base: 4 단계, 이미지 2개 중 1개 Technics SL-1900 Turntable Disassembly, Detach Wires from Base: 4 단계, 이미지 2개 중 2개
    • The tone arm is still connected to the base of the turntable by several wires.
    • The audio cables from the tone arm pass through a plastic stress relief collar where they exit the case. Pull this stress relief collar out of its slot in the case bottom.
    • Remove the screw securing the grounding wire to the large circuit board. Put the screw back in the hole in the circuit board, so it doesn't get lost.
    • After detaching these wires, the tone arm assembly comes free from the base of the turntable.
  5. Technics SL-1900 Turntable Disassembly, Inspect the Turntable Internals: 5 단계, 이미지 3개 중 1개 Technics SL-1900 Turntable Disassembly, Inspect the Turntable Internals: 5 단계, 이미지 3개 중 2개 Technics SL-1900 Turntable Disassembly, Inspect the Turntable Internals: 5 단계, 이미지 3개 중 3개
    • Inspect the internals of the turntable. The unit base still contains the motor, the circuit board, and a bunch of complicated plastic parts.
    • The bottom of the tone arm base contains some springs, wires, and some delicate moving parts. If the grease around the moving parts has hardened, replace it to allow proper operation.
  6. Technics SL-1900 Turntable Disassembly, Lubricate the Tone Arm Lifting Mechanism: 6 단계, 이미지 1개 중 1개
    • If the grease still feels soft and greasy, but nothing happens when you raise the tone arm lever, shoot some spray lube from the top, into the moving pillars of the bar that raises and lowers the tone arm. I used WD-40.
    • After lubricating, work the mechanism by gently pushing and pulling on the bar that raises and lowers the tone arm, while moving the control lever for the tone arm.
    • If you are successful you should observe that the tone arm lift bar slowly rises and falls as you raise and lower the lift control.
  7. Technics SL-1900 Turntable Disassembly, Replace Knobs During Reassembly: 7 단계, 이미지 3개 중 1개 Technics SL-1900 Turntable Disassembly, Replace Knobs During Reassembly: 7 단계, 이미지 3개 중 2개 Technics SL-1900 Turntable Disassembly, Replace Knobs During Reassembly: 7 단계, 이미지 3개 중 3개
    • When reassembling the unit, take special care to reseat the control knobs back onto their controls on the circuit board.
    • First, remove the small plastic cover holding the control knobs captive. From the bottom, release three plastic tabs indicated in red. Then slide the small plastic cover forward, to release the two plastic tabs indicated in yellow.
    • Reseat the control knobs back onto their metal posts.
    • Replace the small plastic cover by inserting the two tabs (yellow) and pushing down to reseat the three tabs (red).
결론
To reassemble your device, follow the rest of these instructions in reverse order.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
gordonhamachi
회원 가입일: 12/20/14
4,533 평판
안내서 20개를 작성함
1가이드 댓글
No information on how to assemble Operating Plate Assembly part SFUB190-21A
RONALD KENNY - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 34
지난 30일: 170
전체 시간: 5,162
