부품
부품은 필요하지 않습니다.
  1. Remove back cover by applying pressure and sliding up towards the top of the phone. Remove back cover by applying pressure and sliding up towards the top of the phone. Remove back cover by applying pressure and sliding up towards the top of the phone.
    • Remove back cover by applying pressure and sliding up towards the top of the phone.
  2. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. Remove the battery by lifting from slot on the right hand side. Remove the battery by lifting from slot on the right hand side.
    • Remove the battery by lifting from slot on the right hand side.
  4. Use Multimeter to test the voltage of the battery. Put the black lead into ground slot of multimeter and the red lead into the V(ohm)mA slot.
    • Use Multimeter to test the voltage of the battery.
    • Put the black lead into ground slot of multimeter and the red lead into the V(ohm)mA slot.
    • Place the red and black leads to the two outside metal plate, each on opposite sides, on the battery as shown.
    • Check that the voltage displayed on the multimeter matches closely to the voltage defined on the battery. Normally 3.7 V.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Melinda Phan
회원 가입일: 2011년 04월 17일
435 평판
안내서 9개 작성하였습니다
Cal Poly, Team 9-64, Walters Spring 2011 Cal Poly, Team 9-64, Walters Spring 2011 회원
CPSU-WALTERS-S11S9G64
5 회원들
안내서 9개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 16
지난 30일: 82
전체 시간: 5,112
