필요한 것
Remove back cover by applying pressure and sliding up towards the top of the phone.
Use Multimeter to test the voltage of the battery.
Put the black lead into ground slot of multimeter and the red lead into the V(ohm)mA slot.
Place the red and black leads to the two outside metal plate, each on opposite sides, on the battery as shown.
Check that the voltage displayed on the multimeter matches closely to the voltage defined on the battery. Normally 3.7 V.
Have in mind that a 100% charged Li-ion battery can measure up to ~4.2 V
Since I'm a total noob, and I'm sure I'm not the only person seeking this information. But could you mention which option to turn the dial to?
Make sure it’s on Direct Current (DC) and probably 20V.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Hello one the question was tablet not telephone and it's really vague how you guys explain these things you need to go to work on your site
yes,not tablet with battery removal difficult
