주요 콘텐츠로 건너뛰기
Technostar Sandwich Toaster Thermal Fuse Replacement
필요한 것
  1. Technostar Sandwich Toaster Thermal Fuse Replacement, Thermal Fuse: 1 단계, 이미지 1/1
    • Open the toaster.
    • Remove the four screws which attach the mold.
  2. Technostar Sandwich Toaster Thermal Fuse Replacement: 2 단계, 이미지 1/2 Technostar Sandwich Toaster Thermal Fuse Replacement: 2 단계, 이미지 2/2
    • Remove the mold to get access to the heating coil.
  3. Technostar Sandwich Toaster Thermal Fuse Replacement: 3 단계, 이미지 1/1
    • Find the thermofuse.
  4. Technostar Sandwich Toaster Thermal Fuse Replacement: 4 단계, 이미지 1/2 Technostar Sandwich Toaster Thermal Fuse Replacement: 4 단계, 이미지 2/2
    • Cut the two wires that connect to the thermal fuse.
  5. Technostar Sandwich Toaster Thermal Fuse Replacement: 5 단계, 이미지 1/2 Technostar Sandwich Toaster Thermal Fuse Replacement: 5 단계, 이미지 2/2
    • Align the thermal fuse with the open wires.
    • Put the spade connectors over the wires.
    • Using pliers, clamp the wires together.
  6. Technostar Sandwich Toaster Thermal Fuse Replacement: 6 단계, 이미지 1/1
    • Replace the molds.
    • Replace the four screws which attach the mold.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
charlottevisser63
회원 가입일: 03/08/17
110 평판
안내서 1개 작성함
댓글 2개
where did u find the replacement fuse? I need a thermal fuse for Breville BSG520XL Panini Duo Grill
mortaz - 답글
how do i test that the reason that my toaster is not working is actually the thermal fuse?
itzsabag - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 29
전체 시간: 4,074
