주요 콘텐츠로 건너뛰기
Teddy Bear Nose Replacement
필요한 것
  1. Teddy Bear Nose Replacement, Nose: 1 단계, 이미지 2개 중 1개 Teddy Bear Nose Replacement, Nose: 1 단계, 이미지 2개 중 2개
    • Rip out about five inches of stitches from around the bear's snout.
  2. Teddy Bear Nose Replacement: 2 단계, 이미지 2개 중 1개 Teddy Bear Nose Replacement: 2 단계, 이미지 2개 중 2개
    • Remove stuffing from around the bear's snout.
  3. Teddy Bear Nose Replacement: 3 단계, 이미지 1개 중 1개
    • Flip the fabric of the snout inside out to expose the back of the plastic nose.
  4. Teddy Bear Nose Replacement: 4 단계, 이미지 2개 중 1개 Teddy Bear Nose Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the plastic backing of the teddy bear's nose (if it's still there). You may have to use pliers.
  5. Teddy Bear Nose Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the nose out of the front of the teddy bear’s face.
  6. Teddy Bear Nose Replacement: 6 단계, 이미지 1개 중 1개
    • Push the front of the new nose through the existing hole in the teddy bear’s face.
  7. Teddy Bear Nose Replacement: 7 단계, 이미지 1개 중 1개
    • Attach the nose backing on the inside of the teddy bear’s nose.
  8. Teddy Bear Nose Replacement: 8 단계, 이미지 1개 중 1개
    • Restuff the teddy bear’s nose with the stuffing you took out.
    • You may need to add more stuffing if the bear’s nose looks flat or deflated.
  9. Teddy Bear Nose Replacement: 9 단계, 이미지 1개 중 1개
    • Thread the needle with about 18 inches of thread the same color as the bear's fur or stitches.
  10. Teddy Bear Nose Replacement: 10 단계, 이미지 3개 중 1개 Teddy Bear Nose Replacement: 10 단계, 이미지 3개 중 2개 Teddy Bear Nose Replacement: 10 단계, 이미지 3개 중 3개
    • Sew the teddy bear’s face using a whip stitch until the opening is completely closed.
    • For help with sewing a whip stitch, follow this guide: How to Sew a Whip Stitch.
  11. Teddy Bear Nose Replacement: 11 단계, 이미지 2개 중 1개 Teddy Bear Nose Replacement: 11 단계, 이미지 2개 중 2개
    • Once the face is completely sewn shut, knot the end of the thread, and cut off the excess.
결승점
작성자
2다른 기여자 명과 함께
Nazib Khan
회원 가입일: 09/28/21
193 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 22
지난 30일: 73
전체 시간: 5,516
