주요 콘텐츠로 건너뛰기
Teddy Bear String Smile Replacement
필요한 것
  1. Teddy Bear String Smile Replacement, String Smile: 1 단계, 이미지 1개 중 1개
    • Using the scissors, cut away the existing string smile from the teddy bear.
  2. Teddy Bear String Smile Replacement: 2 단계, 이미지 2개 중 1개 Teddy Bear String Smile Replacement: 2 단계, 이미지 2개 중 2개
    • Using a water-soluble marker, test a small patch on the teddy bear in the area you will be replacing the smile.
    • Once you have tested the patch and made sure the marker washes off the fabric, sketch the smile in the area you desire.
  3. Teddy Bear String Smile Replacement: 3 단계, 이미지 2개 중 1개 Teddy Bear String Smile Replacement: 3 단계, 이미지 2개 중 2개
    • Take one end of the thread and slide it through the thin hole, or eye, at the top of the needle.
    • Once the needle is threaded with your desired length of string (the length of the smile plus a bit more), tie both ends of the string together in a knot.
  4. Teddy Bear String Smile Replacement: 4 단계, 이미지 2개 중 1개 Teddy Bear String Smile Replacement: 4 단계, 이미지 2개 중 2개
    • At an angle, stick the needle through the back of the ear.
    • Pull the needle through a stitch-length away from the corner of your drawn on mouth.
    • Keep pulling until you feel the tug of the knot on the inside of the smile.
  5. Teddy Bear String Smile Replacement: 5 단계, 이미지 1개 중 1개
    • Stick the needle back through the hole you just made and pull it out a stitch-length away; this starts the backstitch.
    • You will be using the drawn on pattern as a reference.
  6. Teddy Bear String Smile Replacement: 6 단계, 이미지 1개 중 1개
    • Continue the backstitch across the smile area until the smile is complete.
  7. Teddy Bear String Smile Replacement: 7 단계, 이미지 3개 중 1개 Teddy Bear String Smile Replacement: 7 단계, 이미지 3개 중 2개 Teddy Bear String Smile Replacement: 7 단계, 이미지 3개 중 3개
    • Stick the needle through the second-to-last stitch.
    • Pull the needle through, diagonally, and pull it out behind the ear that you started with. This will leave a “tail” hanging from behind the ear.
  8. Teddy Bear String Smile Replacement: 8 단계, 이미지 3개 중 1개 Teddy Bear String Smile Replacement: 8 단계, 이미지 3개 중 2개 Teddy Bear String Smile Replacement: 8 단계, 이미지 3개 중 3개
    • At the longest part of the thread, cut the needle away.
    • Tie the two pieces of thread together into a knot against the back of the ear.
    • Cut away the remaining thread.
결론
And now you’re all set! You get to enjoy more moments with your sentimental piece!
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Khadijah
회원 가입일: 07/24/20
214 평판
안내서 1개를 작성함
UW Tacoma, Team S1-G17, Cardinal Summer 2020 UW Tacoma, Team S1-G17, Cardinal Summer 2020 회원
UWT-CARDINAL-SU20S1G17
1 회원
안내서 3개를 작성함
1가이드 댓글
Please are you able to tell me the brand of this monkey? I’ve been searching for months for this as a replacement for my daughters lost monkey
Kirsty Thomas-Eardley - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 30
전체 시간: 1,826
