주요 콘텐츠로 건너뛰기
Teddy Ruxpin Arm Button Replacement
필요한 것
  1. Teddy Ruxpin Arm Button Replacement, Battery: 1 단계, 이미지 2개 중 1개 Teddy Ruxpin Arm Button Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Arm Button Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Arm Button Replacement: 3 단계, 이미지 1개 중 1개
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Arm Button Replacement, Arms: 4 단계, 이미지 3개 중 1개 Teddy Ruxpin Arm Button Replacement, Arms: 4 단계, 이미지 3개 중 2개 Teddy Ruxpin Arm Button Replacement, Arms: 4 단계, 이미지 3개 중 3개
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Arm Button Replacement: 5 단계, 이미지 1개 중 1개
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Arm Button Replacement: 6 단계, 이미지 3개 중 1개 Teddy Ruxpin Arm Button Replacement: 6 단계, 이미지 3개 중 2개 Teddy Ruxpin Arm Button Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Arm Button Replacement: 7 단계, 이미지 2개 중 1개 Teddy Ruxpin Arm Button Replacement: 7 단계, 이미지 2개 중 2개
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Arm Button Replacement: 8 단계, 이미지 2개 중 1개 Teddy Ruxpin Arm Button Replacement: 8 단계, 이미지 2개 중 2개
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Arm Button Replacement: 9 단계, 이미지 1개 중 1개
    • Unplug the arms from the main body.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Lauren
회원 가입일: 01/23/20
226 평판
안내서 2개를 작성함
Cal Poly, Team S18-G5, White Winter 2020 Cal Poly, Team S18-G5, White Winter 2020 회원
CPSU-WHITE-W20S18G5
4 회원들
안내서 8개를 작성함
4가이드 댓글
All you need are screwdrivers? The most important part is left out! New buttons? Where, how?
embalmerjules - 답글
And how do you replace it?! This just says how to take out old buttons!
Summer-Lynn Morente - 답글
So has anyone figured out how to replace the button?
knrobinson83 - 답글
The plastic part of the button is what broke in my daughter's Teddy Ruxpin. She had a similar toy with a button in its hand that she no longer played with, so I took the plastic button part out of the old toy and fit it onto Teddy Ruxpin. I used the same wires and threaded them through the plastic button, then resoldered the wires to the small board in the button. Works perfectly now.
Eliza Zollicoffer - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 37
전체 시간: 1,245
