주요 콘텐츠로 건너뛰기
Teddy Ruxpin Housing Cover Replacement
필요한 것
  1. Teddy Ruxpin Housing Cover Replacement, Battery: 1 단계, 이미지 1/2 Teddy Ruxpin Housing Cover Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Housing Cover Replacement: 2 단계, 이미지 1/1
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Housing Cover Replacement: 3 단계, 이미지 1/1
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Housing Cover Replacement, Arms: 4 단계, 이미지 1/3 Teddy Ruxpin Housing Cover Replacement, Arms: 4 단계, 이미지 2/3 Teddy Ruxpin Housing Cover Replacement, Arms: 4 단계, 이미지 3/3
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Housing Cover Replacement: 5 단계, 이미지 1/1
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Housing Cover Replacement: 6 단계, 이미지 1/3 Teddy Ruxpin Housing Cover Replacement: 6 단계, 이미지 2/3 Teddy Ruxpin Housing Cover Replacement: 6 단계, 이미지 3/3
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Housing Cover Replacement: 7 단계, 이미지 1/2 Teddy Ruxpin Housing Cover Replacement: 7 단계, 이미지 2/2
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Housing Cover Replacement: 8 단계, 이미지 1/2 Teddy Ruxpin Housing Cover Replacement: 8 단계, 이미지 2/2
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Housing Cover Replacement: 9 단계, 이미지 1/1
    • Unplug the arms from the main body.
  10. Teddy Ruxpin Housing Cover Replacement, Housing Cover: 10 단계, 이미지 1/3 Teddy Ruxpin Housing Cover Replacement, Housing Cover: 10 단계, 이미지 2/3 Teddy Ruxpin Housing Cover Replacement, Housing Cover: 10 단계, 이미지 3/3
    • Unscrew the eleven circled 12.5mm Phillips #1 screws.
    • Remove the top of the housing to access the electronics inside.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jonny Brazil
회원 가입일: 01/23/20
190 평판
안내서 1개 작성함
Cal Poly, Team S18-G5, White Winter 2020 Cal Poly, Team S18-G5, White Winter 2020 회원
CPSU-WHITE-W20S18G5
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 505
