주요 콘텐츠로 건너뛰기
Teenage Engineering OP-1 Connector Board Replacement
필요한 것
  1. Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: 1 단계, 이미지 1/3 Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: 1 단계, 이미지 2/3 Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: 1 단계, 이미지 3/3
    • Open the back panel by using a Jimmy on the side of the panel. Be careful not to damage the OP-1 coating.
    • Lift the back panel and remove it. The Connector Board is revealed.
  2. Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: 2 단계, 이미지 1/3 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: 2 단계, 이미지 2/3 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: 2 단계, 이미지 3/3
    • Disconnect the flex connector by lifting it up with a spudger.
    • Remove the three Phillips screws. Do not lose the washer at the bottom screw.
    • Take out the connector board.
    • Make sure to keep the black rubber pad underneath the board.
  3. Teenage Engineering OP-1 Connector Board Replacement: 3 단계, 이미지 1/2 Teenage Engineering OP-1 Connector Board Replacement: 3 단계, 이미지 2/2
    • Don't forget the cover for the on/off switch.
    • Simply take it off from the old board and transfer it to the new board.
결론
다른 45명이 해당 안내서를 완성하였습니다.
teenage engineering
회원 가입일: 10/23/13
1,077 평판
안내서 2개 작성하였습니다
Teenage Engineering Teenage Engineering 회원
Community
3 회원들
안내서 7개 작성하였습니다
댓글 42개
Veeery useful , thank you !
mouchtouris alexandre - 답글
Even with the Jimmy I can't seem to get the back panel off... a video would be helpful :)
Shawn Ivie - 답글
Got the back panel off finally but my connector board won't come out.
Shawn Ivie - 답글
Ok... finally got the connector board out. It took a bit of gentle prying using a very small thin screw driver bit on each side of the connector board. Once I had the right side popped up a bit I was able to push on the input output jacks from the outside to get clearance. Removing the connector board and putting it back in resolved the power switch issues I was experiencing. No new connector board needed! :)
Shawn Ivie - 답글
Im so glad I was reading these comments. I had an OP1 with failing power as well, every bit more tougher touch would turn it off and on, or sometimes would have problems starting up.
I took it apart to see if something was bothering, and taking off the white power switch actually solved it haha.
Good I didnt order it yet!
J-J -
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 46
30일 전: 239
전체 시간: 46,977
