주요 콘텐츠로 건너뛰기
Teenage Engineering OP-1 Connector Board Replacement
필요한 것
  1. Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: 1 단계, 이미지 3개 중 1개 Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: 1 단계, 이미지 3개 중 2개 Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: 1 단계, 이미지 3개 중 3개
    • Open the back panel by using a Jimmy on the side of the panel. Be careful not to damage the OP-1 coating.
    • Lift the back panel and remove it. The Connector Board is revealed.
  2. Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: 2 단계, 이미지 3개 중 1개 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: 2 단계, 이미지 3개 중 2개 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: 2 단계, 이미지 3개 중 3개
    • Disconnect the flex connector by lifting it up with a spudger.
    • Remove the three Phillips screws. Do not lose the washer at the bottom screw.
    • Take out the connector board.
    • Make sure to keep the black rubber pad underneath the board.
  3. Teenage Engineering OP-1 Connector Board Replacement: 3 단계, 이미지 2개 중 1개 Teenage Engineering OP-1 Connector Board Replacement: 3 단계, 이미지 2개 중 2개
    • Don't forget the cover for the on/off switch.
    • Simply take it off from the old board and transfer it to the new board.
결론
다른 47명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
teenage engineering
회원 가입일: 10/23/13
1,113 평판
안내서 2개를 작성함
44가이드 댓글
Veeery useful , thank you !
mouchtouris alexandre - 답글
Even with the Jimmy I can't seem to get the back panel off... a video would be helpful :)
Shawn Ivie - 답글
Got the back panel off finally but my connector board won't come out.
Shawn Ivie - 답글
Ok... finally got the connector board out. It took a bit of gentle prying using a very small thin screw driver bit on each side of the connector board. Once I had the right side popped up a bit I was able to push on the input output jacks from the outside to get clearance. Removing the connector board and putting it back in resolved the power switch issues I was experiencing. No new connector board needed! :)
Shawn Ivie - 답글
Im so glad I was reading these comments. I had an OP1 with failing power as well, every bit more tougher touch would turn it off and on, or sometimes would have problems starting up.
I took it apart to see if something was bothering, and taking off the white power switch actually solved it haha.
Good I didnt order it yet!
J-J -
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 55
지난 30일: 334
전체 시간: 51,901
