주요 콘텐츠로 건너뛰기
Teenage Engineering OP-Z Back Cover Replacement
  1. Teenage Engineering OP-Z Back Cover Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Teenage Engineering OP-Z Back Cover Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Teenage Engineering OP-Z Back Cover Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Back Cover Replacement: 2 단계, 이미지 2개 중 1개 Teenage Engineering OP-Z Back Cover Replacement: 2 단계, 이미지 2개 중 2개
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Back Cover Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the bottom plate including the rubber feet.
결론
작성자
1다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
129,328 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,145개를 작성함
3가이드 댓글
and uhm where to order the backplate? :/
boombipbass - 답글
Do you not sell the plate anymore?
Jason - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 30
전체 시간: 1,988
