주요 콘텐츠로 건너뛰기
Teenage Engineering OP-Z Battery Replacement
필요한 것
  1. Teenage Engineering OP-Z Battery Replacement, Back Cover: 1 단계, 이미지 1/3 Teenage Engineering OP-Z Battery Replacement, Back Cover: 1 단계, 이미지 2/3 Teenage Engineering OP-Z Battery Replacement, Back Cover: 1 단계, 이미지 3/3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Battery Replacement: 2 단계, 이미지 1/2 Teenage Engineering OP-Z Battery Replacement: 2 단계, 이미지 2/2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Battery Replacement: 3 단계, 이미지 1/1
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Battery Replacement, Battery: 4 단계, 이미지 1/2 Teenage Engineering OP-Z Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Battery Replacement: 5 단계, 이미지 1/2 Teenage Engineering OP-Z Battery Replacement: 5 단계, 이미지 2/2
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
결론
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Ask our Answers community for help.
다른 4명이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
117,293 평판
안내서 188개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,521개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 26
30일 전: 165
전체 시간: 6,844
