주요 콘텐츠로 건너뛰기
Teenage Engineering OP-Z Rubber Feet Replacement
필요한 것
  1. Teenage Engineering OP-Z Rubber Feet Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Teenage Engineering OP-Z Rubber Feet Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Teenage Engineering OP-Z Rubber Feet Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Rubber Feet Replacement: 2 단계, 이미지 2개 중 1개 Teenage Engineering OP-Z Rubber Feet Replacement: 2 단계, 이미지 2개 중 2개
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Rubber Feet Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Rubber Feet Replacement, Rubber Feet: 4 단계, 이미지 1개 중 1개
    • Remove the four Phillips #0 screws from the back of the rubber feet.
  5. Teenage Engineering OP-Z Rubber Feet Replacement: 5 단계, 이미지 2개 중 1개 Teenage Engineering OP-Z Rubber Feet Replacement: 5 단계, 이미지 2개 중 2개
    • Separate the front and rear part of the rubber feet from the back cover.
  6. Teenage Engineering OP-Z Rubber Feet Replacement: 6 단계, 이미지 1개 중 1개
    • When reassembling make sure to correctly align the front and rear part of the rubber feet. The notch and grove should interlock and fit into the cutout of the back cover.
결론
작성자
1다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
129,229 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,145개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 29
전체 시간: 2,054
