주요 콘텐츠로 건너뛰기
Teenage Engineering OP-Z Volume Potentiometer Replacement
필요한 것
  1. Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Volume Potentiometer Replacement: 2 단계, 이미지 2개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 2 단계, 이미지 2개 중 2개
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Volume Potentiometer Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Volume Potentiometer Replacement, Battery: 4 단계, 이미지 2개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Volume Potentiometer Replacement: 5 단계, 이미지 2개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
  6. Teenage Engineering OP-Z Volume Potentiometer Replacement, Expansion Module: 6 단계, 이미지 2개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement, Expansion Module: 6 단계, 이미지 2개 중 2개
    • Use your finger or a spudger to push up on the small tab on the bottom of the module.
    • Lift the module up and out of its recess bottom first.
  7. Teenage Engineering OP-Z Volume Potentiometer Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the module.
    • When inserting another module make sure you put it in outputs first. Then push down the bottom part for the tab to engage.
  8. Teenage Engineering OP-Z Volume Potentiometer Replacement, Midframe: 8 단계, 이미지 1개 중 1개
    • Remove the five Torx T4 screws.
  9. Teenage Engineering OP-Z Volume Potentiometer Replacement: 9 단계, 이미지 2개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 9 단계, 이미지 2개 중 2개
    • Place a spudger in the cutout of the extension module to lift the midframe.
    • Be careful not to damage the highway flex cable underneath.
    • Don’t remove the midframe yet. It is still connected to the rest of the OP-Z.
  10. Teenage Engineering OP-Z Volume Potentiometer Replacement: 10 단계, 이미지 3개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 10 단계, 이미지 3개 중 2개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 10 단계, 이미지 3개 중 3개
    • Flip the midframe over to gain access to the flex cable connector underneath.
  11. Teenage Engineering OP-Z Volume Potentiometer Replacement: 11 단계, 이미지 2개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 11 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to disconnect the flex cable from the front panel assembly.
  12. Teenage Engineering OP-Z Volume Potentiometer Replacement, Highway Flex Cable: 12 단계, 이미지 2개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement, Highway Flex Cable: 12 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the highway flex cable from the DSP board.
  13. Teenage Engineering OP-Z Volume Potentiometer Replacement: 13 단계, 이미지 2개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 13 단계, 이미지 2개 중 2개
    • Use the spudger to disconnect the flex cable from the encoder board.
  14. Teenage Engineering OP-Z Volume Potentiometer Replacement: 14 단계, 이미지 3개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 14 단계, 이미지 3개 중 2개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 14 단계, 이미지 3개 중 3개
    • Slowly pry the USB-C connector out of its recess. Use the flat end of a spudger on the small nib on the USB-C board.
    • The connector is slightly glued down.
  15. Teenage Engineering OP-Z Volume Potentiometer Replacement: 15 단계, 이미지 3개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 15 단계, 이미지 3개 중 2개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 15 단계, 이미지 3개 중 3개
    • Insert the pointy end of the spudger into the line-out jack and lever it up carefully.
    • The jack connector might sit tight and is slightly glued down.
  16. Teenage Engineering OP-Z Volume Potentiometer Replacement: 16 단계, 이미지 3개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 16 단계, 이미지 3개 중 2개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 16 단계, 이미지 3개 중 3개
    • The highway flex cable is slightly adhered to the midframe. To remove it, gently push it out from underneath.
    • A small transparent part may pop out. This is the light guide for the bluetooth indicator. Just hinge it back onto the midframe as seen here.
  17. Teenage Engineering OP-Z Volume Potentiometer Replacement: 17 단계, 이미지 3개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 17 단계, 이미지 3개 중 2개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 17 단계, 이미지 3개 중 3개
    • Peel the highway flex cable off the midframe and remove it.
  18. Teenage Engineering OP-Z Volume Potentiometer Replacement, Volume Pot: 18 단계, 이미지 2개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement, Volume Pot: 18 단계, 이미지 2개 중 2개
    • Use one arm of a tweezer to lift the small black flap of the ZIF connector.
  19. Teenage Engineering OP-Z Volume Potentiometer Replacement: 19 단계, 이미지 2개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 19 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of flat nose tweezers to pull the small flex cable up and out out the ZIF connector.
    • When reassembling make sure to insert the flex cable all the way.
  20. Teenage Engineering OP-Z Volume Potentiometer Replacement: 20 단계, 이미지 2개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 20 단계, 이미지 2개 중 2개
    • Grab the volume knob with your fingers or a pair of pliers and pull it off its axle.
  21. Teenage Engineering OP-Z Volume Potentiometer Replacement: 21 단계, 이미지 2개 중 1개 Teenage Engineering OP-Z Volume Potentiometer Replacement: 21 단계, 이미지 2개 중 2개
    • Use a spudger to lever up the axle of the volume potentiometer. This way it will clear the frame’s cutout.
    • The volume pot is slightly glued down.
  22. Teenage Engineering OP-Z Volume Potentiometer Replacement: 22 단계, 이미지 1개 중 1개
    • Remove the volume potentiometer.
결론
작성자
3다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
129,301 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,145개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 24
전체 시간: 1,548
