주요 콘텐츠로 건너뛰기
Tefal Thick N Thin Toaster 815032 Side Panels Replacement
필요한 것
  1. Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: 1 단계, 이미지 1/3 Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: 1 단계, 이미지 2/3 Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: 1 단계, 이미지 3/3
    • Turn the toaster upside down.
    • Remove the four 10 mm screws from the bottom of the toaster using a TR9 Torx screwdriver.
    • Remove the 14 mm Torx-slot combination screw on the opposite side of the toaster's lever with a TR9 Torx screwdriver.
    • Remove the 11 mm Torx-slot combination screw near the toaster's lever with a TR9 Torx screwdriver.
  2. Tefal Thick N Thin Toaster 815032 Side Panels Replacement: 2 단계, 이미지 1/1
    • Remove the side of the toaster that does not have the lever.
    • The side will just pop off, as you have removed the screw holding it in place.
  3. Tefal Thick N Thin Toaster 815032 Side Panels Replacement: 3 단계, 이미지 1/2 Tefal Thick N Thin Toaster 815032 Side Panels Replacement: 3 단계, 이미지 2/2
    • Remove the 10 mm screw from the top of the remaining side of the toaster using a TR9 Torx screwdriver.
    • This side will pop off as well once you have removed the screw.
    • The toaster's lever and heating slide will fall off with a simple pull.
결론
Kristen Gismondi
회원 가입일: 11/12/14
82,716 평판
안내서 202개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,430개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 5
30일 전: 9
전체 시간: 192
