주요 콘텐츠로 건너뛰기
Tektro Aires Disc Brakes Brake Pad Replacement
필요한 것
  1. Tektro Aires Disc Brakes Brake Pad Replacement, Brake Pad: 1 단계, 이미지 1개 중 1개
    • Bend the retention pins straight using a pair of needle nose pliers.
  2. Tektro Aires Disc Brakes Brake Pad Replacement: 2 단계, 이미지 2개 중 1개 Tektro Aires Disc Brakes Brake Pad Replacement: 2 단계, 이미지 2개 중 2개
    • Loosen the two mounting bolts using a 5mm Hex Key.
    • Different bike models will have the mounting points in different locations.
  3. Tektro Aires Disc Brakes Brake Pad Replacement: 3 단계, 이미지 1개 중 1개
    • After removing the bolts pull of the brake caliper from the brake disc.
  4. Tektro Aires Disc Brakes Brake Pad Replacement: 4 단계, 이미지 1개 중 1개
    • Using the needle nose pliers remove the retention pin by pulling on it.
  5. Tektro Aires Disc Brakes Brake Pad Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the brake pads by pulling on them and releasing them from the caliper.
  6. Tektro Aires Disc Brakes Brake Pad Replacement: 6 단계, 이미지 1개 중 1개
    • Place the spring on the new Tektro Disc Brake Pad as shown.
    • The other brake pad will go on the spring opposite the first brake pad.
결론
  • The steps for the front wheel are the same as the back wheel.
  • Follow steps in reverse for reassembly.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Randall Eakes
회원 가입일: 10/26/21
199 평판
안내서 1개를 작성함
1가이드 댓글
Why did you change the spelling of brakes half way through?
Brian Haddock - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 36
지난 30일: 179
전체 시간: 7,761
