주요 콘텐츠로 건너뛰기
Telecaster Guitar String(s) Replacement
필요한 것
  1. Telecaster Guitar String(s) Replacement, Unwind the Guitar Strings: 1 단계, 이미지 3개 중 1개 Telecaster Guitar String(s) Replacement, Unwind the Guitar Strings: 1 단계, 이미지 3개 중 2개 Telecaster Guitar String(s) Replacement, Unwind the Guitar Strings: 1 단계, 이미지 3개 중 3개
    • Start with the low E string (the furthest on the right). Unwind the string by turning the tuning peg counter-clockwise.
    • Keep the string secure by placing one finger on the string's nut slot.
    • After unwinding the string, the segment coiled around the post will come loose. Pull the string out of the post.
  2. Telecaster Guitar String(s) Replacement, Remove Old Strings: 2 단계, 이미지 3개 중 1개 Telecaster Guitar String(s) Replacement, Remove Old Strings: 2 단계, 이미지 3개 중 2개 Telecaster Guitar String(s) Replacement, Remove Old Strings: 2 단계, 이미지 3개 중 3개
    • Uncoil the end of the string as much as possible.
    • Caution: Use caution in handling the ends of strings as they are extremely sharp.
    • Pull the end of the string through the bridge and out through the back of the guitar.
  3. Telecaster Guitar String(s) Replacement, Insert New Strings: 3 단계, 이미지 3개 중 1개 Telecaster Guitar String(s) Replacement, Insert New Strings: 3 단계, 이미지 3개 중 2개 Telecaster Guitar String(s) Replacement, Insert New Strings: 3 단계, 이미지 3개 중 3개
    • Insert the pointed end of the new string through the corresponding hole on the back of the guitar.
    • Turn the guitar over and pull the string all the way through.
  4. Telecaster Guitar String(s) Replacement, Clip Excess String: 4 단계, 이미지 3개 중 1개 Telecaster Guitar String(s) Replacement, Clip Excess String: 4 단계, 이미지 3개 중 2개 Telecaster Guitar String(s) Replacement, Clip Excess String: 4 단계, 이미지 3개 중 3개
    • There will be extraneous string length while replacing the 5th and 6th (furthest to the right) strings. Using a wire cutter, you may opt to trim the length of these strings.
    • Stretch out the replacement string and cut it about 3-4 peg lengths away from the peg of the string you're replacing. In this case, you are replacing the 5th string and will cut the string near the 2nd string peg.
  5. Telecaster Guitar String(s) Replacement, Insert String into Peg: 5 단계, 이미지 3개 중 1개 Telecaster Guitar String(s) Replacement, Insert String into Peg: 5 단계, 이미지 3개 중 2개 Telecaster Guitar String(s) Replacement, Insert String into Peg: 5 단계, 이미지 3개 중 3개
    • Insert the end of the cut string into the middle hole of the corresponding peg.
    • Keep pushing the end of the string to the bottom and bend the string until the outside segment touches the bottom of the guitar head.
  6. Telecaster Guitar String(s) Replacement, Tighten Strings & Tune Guitar: 6 단계, 이미지 3개 중 1개 Telecaster Guitar String(s) Replacement, Tighten Strings & Tune Guitar: 6 단계, 이미지 3개 중 2개 Telecaster Guitar String(s) Replacement, Tighten Strings & Tune Guitar: 6 단계, 이미지 3개 중 3개
    • Pushing the end of the string to the bottom and the outside segment to the guitar head, turn the tuning peg clockwise.
    • When the string is tight enough, you may release it. Make sure the string fits securely within the nut slot.
    • Using a tuner of your choice, tighten the guitar string until it matches the correct pitch.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jasper
회원 가입일: 04/11/21
214 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 30
지난 30일: 112
전체 시간: 9,964
