소개
This will show you how to change the rocker switch on the Blaupunkt TV
필요한 것
Removing the power switch is quite simple. First open the case by removing all screws on the back panel, which are marked with an arrow. (ATTENTION: different lengths and strengths! - Remember which screw goes where when unscrewing).
Then carefully lift off the back panel and disconnect any cables that prevent the back panel from being lifted off. Now press the retaining clips that hold the switch in the TV housing together with needle-nose pliers and clip the switch out of the TV housing. (use a flat-blade screwdriver if necessary).
As mentioned before - connect the cable to the new switch and snap the snap-in switch back into the housing. Replace the back panel and screw the screws back in where they were unscrewed.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
