주요 콘텐츠로 건너뛰기
Telikin Elite Silver 22in Touchscreen Computer
필요한 것
  1. Telikin Elite Silver 22in Touchscreen Computer, Front glass removal: 1 단계, 이미지 1개 중 1개
    • Lay the computer down on a flat surface
    • Put your suction cups on the top corners of the screen
    • Pull upwards in an arching motion trying to pull the front glass towards yourself. It's held in place with magnets, some force may be required.
  2. Telikin Elite Silver 22in Touchscreen Computer, Front glass ribbon cable removal: 2 단계, 이미지 1개 중 1개
    • Disconnect the ribbon cables.
    • While wearing gloves remove the front glass and place it to the side
  3. Telikin Elite Silver 22in Touchscreen Computer, Screen bracket removal: 3 단계, 이미지 1개 중 1개
    • Remove the brackets on the top corners of the screen using a Phillips head screwdriver, put aside for reassembly.
  4. Telikin Elite Silver 22in Touchscreen Computer, Moving the screen out of the way: 4 단계, 이미지 1개 중 1개
    • Once the screen is unscrewed pull in a similar arching motion as you did the front glass.
  5. Telikin Elite Silver 22in Touchscreen Computer, Reasembily tips: 5 단계, 이미지 1개 중 1개
    • When reassembling, ensure that the screen is flush with all four corners. Otherwise it will not seat back into the chassis properly.
  6. Telikin Elite Silver 22in Touchscreen Computer: 6 단계, 이미지 1개 중 1개
    • This is the INCORRECT way to put the brackets back on, the bend point should be facing upwards
    • As some of the screws are next to the magnets, you may want to use a pair of pliers or tweezers to get them started in the holes
결론
작성자
1다른 기여자 명과 함께
Frank_64
회원 가입일: 09/12/25
283 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 33
전체 시간: 73
