주요 콘텐츠로 건너뛰기
Tello Quadcopter Propeller Replacement
필요한 것
  1. Tello Quadcopter Propeller Replacement, Propeller: 1 단계, 이미지 1/1
    • Identify the propeller being replaced.
    • Gather the required materials.
  2. Tello Quadcopter Propeller Replacement: 2 단계, 이미지 1/2 Tello Quadcopter Propeller Replacement: 2 단계, 이미지 2/2
    • Next, remove the battery by grasping each side and pulling it out.
  3. Tello Quadcopter Propeller Replacement: 3 단계, 이미지 1/3 Tello Quadcopter Propeller Replacement: 3 단계, 이미지 2/3 Tello Quadcopter Propeller Replacement: 3 단계, 이미지 3/3
    • Remove the propeller by inserting the provided tool between the propeller and drone.
    • Needle nose pliers can be used instead. Use the pliers to grasp directly below the propeller.
    • Gently lift the propeller from the socket using your choice of tool.
  4. Tello Quadcopter Propeller Replacement: 4 단계, 이미지 1/3 Tello Quadcopter Propeller Replacement: 4 단계, 이미지 2/3 Tello Quadcopter Propeller Replacement: 4 단계, 이미지 3/3
    • After removing the old propeller, orient the new propeller over the empty socket.
    • Insert a new propeller by applying force. The propeller should snap into place.
결론
You have successfully completed replacing the damaged propellor.
Cody White
회원 가입일: 10/08/20
109 평판
안내서 1개 작성함
University of Memphis, Team S2-G2, Willis Fall 2020 University of Memphis, Team S2-G2, Willis Fall 2020 회원
UM-WILLIS-F20S2G2
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 35
전체 시간: 1,887
