주요 콘텐츠로 건너뛰기
Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven
필요한 것
  1. Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven, Check the Warranty: 1 단계, 이미지 1/1
    • Send the card back to the manufacturer for repairs if the warranty is valid. This procedure will void your warranty.
    • Check to see if your warranty is valid. This can be done by looking up the serial number of your graphics card for retail cards in most situations. For OEM video cards, the warranty is tied to the system and may expire sooner then a retail card.
  2. Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven, Remove the card from the System: 2 단계, 이미지 1/1
    • If the graphics card is still installed into the system, begin by removing the card.
    • Unplug all applicable cables from the graphics card as highlighted in blue, your card may have more or less cables
  3. Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven: 3 단계, 이미지 1/1
    • To remove your card you'll need to remove the screw(s) from the back of the card
    • After doing so ensure that there is no other things blocking the card from being removed from the motherboard
    • Remove the card from the PC
  4. Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven, Parts and Materials: 4 단계, 이미지 1/1
    • Precision screwdriver(s): usually Phillips #0 and/or #1.
    • Aluminum foil to cover heat sensitive components while propping the card up onto the tray.
    • Thermal paste to replace the paste afterwards.
    • Paper towels to rub any excess of old heatsink compound from the components. (Alcohol wipes work as-well)
    • An oven.
    • A baking tray.
  5. Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven, Oven Preperation: 5 단계, 이미지 1/1
    • Preheat the oven to 385F (195C).
    • Experiment with lower heats first, and increase temperature as necessary.
    • If you've already finished this guide once and are baking again, increase the temperature slightly - 395F (200C) or 400F (205C).
    • Most of these temporary repairs only consist of the expanding/shrinking of bumps under the surface mount of the graphics chip. Therefore, a lower heat may work as well.
  6. Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven, Card Dissasembly: 6 단계, 이미지 1/2 Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven, Card Dissasembly: 6 단계, 이미지 2/2
    • While the oven is pre-heating:
    • Locate specific guides for disassembling your GPU if these steps are inapplicable to your GPU.
    • Remove the screws or clips holding your fan and any duct-work to the video card.
    • Gently take the fan/duct-work off.
    • Remove any old heatsink compound from the chips (using a paper towel).
    • Place the screws in a safe place.
    • Remove plastic components. Plastic will melt in the oven, and produce toxic fumes.
    • Elevate GPU around the edges, never let the components touch any surface.
  7. Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven, Solder Melting Point: 7 단계, 이미지 1/1
    • Use any provided times as an estimate - different materials melt at different temperatures.
    • Heat the GPU slowly.
    • GPU completion times: PS: 3-6 minutes, Xbox: 4-6 minutes, desktop boards: 12 minutes, laptop boards: 8 - 12 minutes, GFX: 8 - 15 minutes.
    • Be patient. If your oven has a window, check if the solder has melted visibly.
    • Set the timer on your oven for 5 -10 minutes.
  8. Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven, Heat the GPU: 8 단계, 이미지 1/2 Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven, Heat the GPU: 8 단계, 이미지 2/2
    • Prevent the GPU components from touching any surface by elevating the edges of the card with foil.
    • Do not leave the oven unattended.
    • Place the GPU on a baking sheet with the side with most of the chips facing up.
    • Place the baking sheet or dish in the middle of the oven.
  9. Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven, Venting and Cooling: 9 단계, 이미지 1/1
    • Vent the oven 5 - 10 times by opening the door. This will regulate temperature.
    • Movements can cause liquid solder to solidify incorrectly and ruin the card.
    • You will notice a smell from the molten solder/flux.
    • Do not use fans for cooling.
  10. Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven, Test the GPU: 10 단계, 이미지 1/1
    • You have 2 options:
    • 1. Test the card quickly without reinstalling the fan/heatsink.
    • Do not operate the GPU with heatsink/fan removed for more than 30 seconds.
    • 2. Reinstall the fan/heatsink, then test the card.
    • Repeat steps 2-9 if GPU fails test.
    • Proceed to step 10 if GPU passes test.
    • Most people will want to test the card to see if it powers on and passes the POST.
  11. Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven, Installing Heatsink: 11 단계, 이미지 1/2 Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven, Installing Heatsink: 11 단계, 이미지 2/2
    • Apply thermal paste onto the main chip or on the connection side of the fan.
    • Place the heat-sink over the GPU carefully, lining up any screws or clips.
    • Apply heatsink on thermal pads as applicable.
    • Use only a small amount of heatsink and spread evenly using a card, or apply pressure evenly when connecting components.
    • If there is thermal tape or pads that were removed for the reflow, place these back in their original position.
  12. Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven, Reinstalling Fans/ Cleaning GPU: 12 단계, 이미지 1/2 Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven, Reinstalling Fans/ Cleaning GPU: 12 단계, 이미지 2/2
    • Insert and tighten all the screws carefully. They are quite small, and the PCB may be damaged if the screws are over tightened.
    • Tighten the screws in an alternating pattern. E.G. Top left, Bottom right, Top right, Bottom left. With more than 4 screws, use a "Star" pattern when tightening the screws ensuring all screws are evenly tightened.
    • Clean off any noticeable dust on the GPU.
  13. Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven, Reinstall GPU: 13 단계, 이미지 1/1
    • Reinsert GPU into GPU slot on motherboard.
    • Monitor GPU temperatures while PC is at idle, opening programs, while performing intensive tasks.
    • GPUs overheat at around 90C
  14. Temporarily Repair a Lost Cause Graphics Card by Heating it up in an oven, Final Check: 14 단계, 이미지 1/1
    • Verify that the fan was reconnected (if there is one).
    • Verify that the fan spins when the PC is powered up.
    • Verify the GPU works and is detectable by the system.
    • A good program to get is GPU-Z. it can display the GPU temperature on supported cards.
결승점
다른 65명이 해당 안내서를 완성하였습니다.
Gaspard Leon
회원 가입일: 04/24/10
2,831 평판
안내서 8개 작성하였습니다
댓글 103개
I fixed my friends dead out-of-warranty Leadtek Geforce 8800 GTS 640MB card using this procedure
That was 3 weeks ago, and he's still using it daily since then
We forgot to plug in the fan connector and his temperatures reached 124C while playing a game
Since then he reconnected his fan and it's working fine
Thanks for reading, hope it helps someone
Gaspard Leon - 답글
How long did your reflowed graphics card last? Is it still rocking?
Lim Chi Yuung -
The card did eventually fail, i believe around 4 months later - the guy ended up buying a new card
Gaspard Leon -
Hi everyone,
I also fixed a almost dead NVIDIA 512mb MXM II card, at the first point I put the card 8 min to 190ºC aprox, it improved the performance but not yet to run.
Then i repeated the operation with 205ºC and 10 min and the card ran perfectly, add some thermal paste and it's solved.
Thanks for this manual it's very usefull!!!
javier - 답글
I just finished doing this with an evga gtx460 i got from a friend of mine. It was throwing up artifacts and crashing constantly before. Now it's stable for over 10 minutes. It looks like it's fixed but only time will tell. Wish me luck and thanks for the guide!
Chris S - 답글
댓글 쓰기
조회 통계:
24 시간 전: 46
7일 전: 301
30일 전: 1,378
전체 시간: 403,158
