주요 콘텐츠로 건너뛰기
Tengda S5 Plus Home Button Replacement
필요한 것
  1. Tengda S5 Plus Home Button Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Place the phone screen-side down.
  2. Tengda S5 Plus Home Button Replacement: 2 단계, 이미지 2개 중 1개 Tengda S5 Plus Home Button Replacement: 2 단계, 이미지 2개 중 2개
    • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
    • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
  3. Tengda S5 Plus Home Button Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Remove the battery by placing your thumb in the slot, pushing the battery up and pulling it out.
  4. Tengda S5 Plus Home Button Replacement, Home Button: 4 단계, 이미지 1개 중 1개
    • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
    • Keep these screws in a safe place. They are very small and easy to lose.
  5. Tengda S5 Plus Home Button Replacement: 5 단계, 이미지 2개 중 1개 Tengda S5 Plus Home Button Replacement: 5 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, create a small gap between the front screen and the metal casing. Slide the plastic opening tool around the phone counterclockwise to make this gap around the entire phone.
    • Once the screen is separated from the back panel, pull the two pieces apart.
  6. Tengda S5 Plus Home Button Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Lay your device with the screen faced down.
    • Using tweezers, lift the two pieces of yellow tape holding the wire in place.
  7. Tengda S5 Plus Home Button Replacement: 7 단계, 이미지 2개 중 1개 Tengda S5 Plus Home Button Replacement: 7 단계, 이미지 2개 중 2개
    • Using the tweezers again, grasp the wire and free it from the crevice.
    • This will provide slack for you to work with the lower motherboard.
  8. Tengda S5 Plus Home Button Replacement: 8 단계, 이미지 3개 중 1개 Tengda S5 Plus Home Button Replacement: 8 단계, 이미지 3개 중 2개 Tengda S5 Plus Home Button Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the silver tape that holds the lower motherboard to the front panel of the phone.
  9. Tengda S5 Plus Home Button Replacement: 9 단계, 이미지 2개 중 1개 Tengda S5 Plus Home Button Replacement: 9 단계, 이미지 2개 중 2개
    • Using your fingers, or the Metal Spudger, disconnect the black cable connector.
    • The cable connector should easy snap out with little force.
  10. Tengda S5 Plus Home Button Replacement: 10 단계, 이미지 3개 중 1개 Tengda S5 Plus Home Button Replacement: 10 단계, 이미지 3개 중 2개 Tengda S5 Plus Home Button Replacement: 10 단계, 이미지 3개 중 3개
    • Using your fingers, slide the lower motherboard towards you.
    • The lower motherboard will still be attached to the front panel by a red and blue cable on the left side and a long silver wire on the right side, but you should now have visibility of the home button.
  11. Tengda S5 Plus Home Button Replacement: 11 단계, 이미지 2개 중 1개 Tengda S5 Plus Home Button Replacement: 11 단계, 이미지 2개 중 2개
    • Clean away any dirt from the back side of the lower motherboard, underneath the charging port.
    • Using tweezers, grasp and remove the home button.
결론
작성자
4다른 기여자 명과 함께
Kenny Levy
회원 가입일: 04/20/15
125 평판
안내서 1개를 작성함
Cal Poly, Team 14-9, Amido Spring 2015 Cal Poly, Team 14-9, Amido Spring 2015 회원
CPSU-AMIDO-S15S14G9
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 497
