주요 콘텐츠로 건너뛰기
Tengda S5 Plus Rear Camera Replacement
필요한 것
  1. Tengda S5 Plus Rear Camera Replacement, Back Panel: 1 단계, 이미지 1/1
    • Place the phone screen-side down.
  2. Tengda S5 Plus Rear Camera Replacement: 2 단계, 이미지 1/2 Tengda S5 Plus Rear Camera Replacement: 2 단계, 이미지 2/2
    • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
    • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
  3. Tengda S5 Plus Rear Camera Replacement, Battery: 3 단계, 이미지 1/1
    • Remove the battery by placing your thumb in the slot, pushing the battery up and pulling it out.
  4. Tengda S5 Plus Rear Camera Replacement, Rear Camera: 4 단계, 이미지 1/1
    • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
    • Keep these screws in a safe place. They are very small and easy to lose.
  5. Tengda S5 Plus Rear Camera Replacement: 5 단계, 이미지 1/2 Tengda S5 Plus Rear Camera Replacement: 5 단계, 이미지 2/2
    • Using the plastic opening tool, create space between the front screen and the metal casing.
    • Once the screen is separated from the back panel, pull the two pieces apart.
  6. Tengda S5 Plus Rear Camera Replacement: 6 단계, 이미지 1/1
    • Place the phone facing screen down.
    • Using the plastic prying tool, gently disconnect the black connector cable.
    • The connector cable should easy snap out with little force.
  7. Tengda S5 Plus Rear Camera Replacement: 7 단계, 이미지 1/1
    • Using the plastic prying tool, pry the camera from the tape holding it in place.
    • Be careful not to rip the tape.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jholmesford
회원 가입일: 04/21/15
188 평판
안내서 1개 작성함
Cal Poly, Team 14-9, Amido Spring 2015 Cal Poly, Team 14-9, Amido Spring 2015 회원
CPSU-AMIDO-S15S14G9
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 274
