주요 콘텐츠로 건너뛰기
Tennis Racquet Grip Tape Replacement
필요한 것
  1. Tennis Racquet Grip Tape Replacement, Tennis Racket Grip Tape: 1 단계, 이미지 1/2 Tennis Racquet Grip Tape Replacement, Tennis Racket Grip Tape: 1 단계, 이미지 2/2
    • Pull the rubber collar towards the tennis racquet head off the handle.
  2. Tennis Racquet Grip Tape Replacement: 2 단계, 이미지 1/1
    • Unwrap the tape on the tennis racquet handle top.
  3. Tennis Racquet Grip Tape Replacement: 3 단계, 이미지 1/3 Tennis Racquet Grip Tape Replacement: 3 단계, 이미지 2/3 Tennis Racquet Grip Tape Replacement: 3 단계, 이미지 3/3
    • Remove the old grip.
    • Some older tennis racquets may have a few staples holding the grip to the buttcap. Use the staple remover to take them out.
  4. Tennis Racquet Grip Tape Replacement: 4 단계, 이미지 1/1
    • Peel off 6 inches of the paper backing covering the adhesive from the replacement grip.
  5. Tennis Racquet Grip Tape Replacement: 5 단계, 이미지 1/2 Tennis Racquet Grip Tape Replacement: 5 단계, 이미지 2/2
    • Face the racquet so the buttcap is towards you.
    • If you are left-handed, wrap the tape towards the right. This method is what is used in the photos.
    • If you are right-handed, wrap the tape towards the left
    • Wrap the grip flush with the buttcap base.
  6. Tennis Racquet Grip Tape Replacement: 6 단계, 이미지 1/2 Tennis Racquet Grip Tape Replacement: 6 단계, 이미지 2/2
    • Wrap the handle at a steady incline, peeling off the backing 6 inches at a time.
    • Stop wrapping just before you finish wrapping the handle.
    • The handle is the off color or unpainted portion below the tennis racquet head.
  7. Tennis Racquet Grip Tape Replacement: 7 단계, 이미지 1/2 Tennis Racquet Grip Tape Replacement: 7 단계, 이미지 2/2
    • Wrap the handle top with the backing on.
    • Mark a horizontal line parallel to the buttcap around the grip.
  8. Tennis Racquet Grip Tape Replacement: 8 단계, 이미지 1/1
    • Cut along the marked line using either scissors or a knife.
    • Cutting with scissors is significantly easier, however if you do not have scissors that can cut the grip, a knife will work.
  9. Tennis Racquet Grip Tape Replacement: 9 단계, 이미지 1/1
    • Remove the backing and finish wrapping the replacement grip.
  10. Tennis Racquet Grip Tape Replacement: 10 단계, 이미지 1/1
    • Wrap the tape that comes with the grip around the handle halfway on the racquet and halfway on the grip.
  11. Tennis Racquet Grip Tape Replacement: 11 단계, 이미지 1/2 Tennis Racquet Grip Tape Replacement: 11 단계, 이미지 2/2
    • Complete your fix by pulling the rubber collar back to its original location.
    • If you do not wish to add an overgrip, skip step 12.
  12. Tennis Racquet Grip Tape Replacement: 12 단계, 이미지 1/1
    • Pull the collar up off the handle.
    • Repeat steps 4 - 11 to apply the overgrip.
결론
Congratulations, your racquet grip is now fixed and you can go out and continue playing!
다른 6명이 해당 안내서를 완성하였습니다.
Aisleen Santos
회원 가입일: 04/28/17
196 평판
안내서 1개 작성함
UC Davis, Team S3-G1, Coad Spring 2017 UC Davis, Team S3-G1, Coad Spring 2017 회원
UCD-COAD-S17S3G1
3 회원들
안내서 2개 작성하였습니다
댓글 4개
Thank you I’ve found particularly useful the, then obvious when you think about it, comment that left handed setup is different to the right handed one!
Sam Curti - 답글
now this was helpfull, What's the difference between Eastern grip and Continental grip? Are they basically the same grip?
JACKSON RYAN - 답글
This guide about tennis grip was worth reading and helped to develop my skills to the next level.
Tennis Unit - 답글
I use this tennis guide, it’s quite worthy.
Rondaromero - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 17
30일 전: 78
전체 시간: 18,389
