소개
For this repair you will be removing your old grip and replacing it with a new Replacement Grip that you purchased from a sports store. This guide will also explain how to apply an Overgrip that you may have purchased for a variety of reasons: disliking the texture of the replacement grip, feeling you want a thicker grip, or simply wish to protect the more expensive Replacement Grip.
필요한 것
Pull the rubber collar towards the tennis racquet head off the handle.
Congratulations, your racquet grip is now fixed and you can go out and continue playing!
다른 6명이 해당 안내서를 완성하였습니다.
댓글 4개
now this was helpfull, What's the difference between Eastern grip and Continental grip? Are they basically the same grip?
This guide about tennis grip was worth reading and helped to develop my skills to the next level.
I use this tennis guide, it’s quite worthy.
